there is no 25volts to the compressor contactor in the outside unit. there is 240vac at the input side of the contactor. where does the coil voltage come from? the model#CLT30-1-B. the unit is only 3 years old. is it still under warranty?
I am istalling a Fujitsu mini split heat pum with two zones. I am prepared to pressure and vacuum...
(More)
I am istalling a Fujitsu mini split heat pum with two zones. I am prepared to pressure and vacuum test system. There are 3way and 2way valves on outside unit. How do I determine correct postion to pressure test and then to perform initial charge from outside unit?
ochtigheid wasschafte lw 44 6weken geleden aan vochtigheid was toen tussen 48 en 56. nu is het...
(More)
ochtigheid wasschafte lw 44 6weken geleden aan vochtigheid was toen tussen 48 en 56. nu is het tussen 38 en 42. Wat is de juiste graad en wat is hier aan te toen. Maak schoon om de 2 weken.
