Question about Mitsubishi WS-65807 65" Rear Projection Television
Screen is distorted on the top and bottom
On the top and bottom of the screen, the edges are curving down. In the middle of the screen the picture is fine. As the image goes towards the edges, the top goes up and out of the range of the viewing area, and the bottom goes down. On espn for example, you can not see the crawl of scores on the bottom of the screen. Occasionally it will appear correctly, but usually only for a short time. TV is 6 years old, bought in 2001.
  • Anonymous Mar 16, 2014
    Barely see top edge of crawling score and writing on bottom of picture
    Genius:
  • 1,153 Answers
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Posted on Sep 13, 2007
SOURCE:
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Picture is extremely distorted
generally Samsung makes great units. but its definitely not worth fixing. recycle it and indvest in a new unit.
mj
Dec 22, 2008 | Samsung DynaFlat TX-P2775H 27" TV
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section  good luck.
Nov 01, 2007 | Televison & Video
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
