Question about LaCie (301146U) 320 GB FireWire 400 (1394a) Hard Drive
LaCie FireWire drive
I have a 120GB external firewire drive and my PC won't see the drive and has issues even recognizing the internal firewire card. I am running Windows XP SP2.
    Novelist:
    Champion:
  • 382 Answers
I would seek out the latest drivers for the card in addition to checking to see the firewire card is properly installed. I would test the cable with another or ports. The D2 has a various array and combination of Firewire ports on each model. Also, try bringing the drive to another computer, to eliminate all other variables. Always of course, properly eject external hardrives and wait for confirmation whenever disconnecting it from the computer, and allow the drive to spin down before turning it off.
Posted on Sep 18, 2007
SOURCE:
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
Can't open folders in same window
it is a trojan download trojan remover and also run malawarebytes they are free and safe to use
May 07, 2009 | LaCie 320GB P3 Firewire External FireWire...
Got a 5-year old Lacie 160 gb that had been used as a Mac backup.
This external hard drive is a firewire and if your laptop does not have firewire ports, then you can't use
it, but if you have a desktop, then there are solutions to your problem in the form of a firewire card.
There is no such thing as an adaptor for a firewire cable, since firewire is an entirely different technology
than the ports your PC presently has.
Firewire is an extremely high speed technology which exceeds the speed of usb and other kinds of ports.
You can get a firewire card for as little as $13.00 here
Apr 09, 2009 | LaCie (300740) 160 GB Hard Drive
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Sep 24, 2007 | LaCie d2 (300769) 200 GB Hard Drive
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 1000gb external drive
I own a Lacie product that does the same thing. It uses firewire but it was clicking a few times and then would not display as a drive. I moved to another computer (with a different firewire card) and it worked. I decided that the firewire card was the issue at the time, but the card still read other devices like digital video camera. I know you are using the USB 2.0 cable. Can you try your drive on a different computer? That would narrow the possible solutions down.
Jun 26, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie (301146U) 320 GB FireWire 400 (1394a) Hard Drive Logo
154 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
