Back to:
Tags:
GE DVL223GB Gas Dryer
Dryer suddenly stopped - F&P ED56 Autosensing Dryer (by 9 users)
posted by tonianderick on Sep 09, 2007
I'm not too sure what the problem is, but I put a load of washing in the dryer & it was working fine, but it suddenly stopped. I opened it to check as it was as if the load had finished, but it was still wet. I closed the dryer up again and pressed the start button, but it wouldn't work. I then pressed the power button which wouldn't work either. I unplugged the dryer and plugged it back in, and it let me press the power button on it again, but still wouldn't start. I'm at a loss as to what to do now!!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by mshomemaker, posted on Mar 14, 2008
My dryer is making a humming noise when I press the start button. It does not work. I tried unplugging it and replugged it. It still does not work.
Comment by Guest, posted on Dec 31, 2007
dryer was working but suddenly it will not start at all. I opened the door and pushed the door button to see if was the door switch but that wasn't the
problem. It has power but it will not start.
Comment by barryasus, posted on Dec 28, 2007
lights on the panel come on and the switch clicks when it is pressed.circuit breakers are on,dryer door switch works properly because when you open the door after pushing in the switch the panel goes into the pause mode as it should if the dryer were spinning. the dryer did not make any noise or stop heating or anything like that, it simply will not start spinning when the switch is depressed no mater what selection you make. when you press the switch you hear a click sound behind the switch similar to what a relay would sound like when activated. no hum or any other noise.
Comment by Guest, posted on Dec 17, 2007
i used the driver, and it worked, took out the clothes, minutes later, and it wouldnt work. it made the noise, when, i pressed the switch like a humming noise, but the drum didnt tumble
Comment by Taylorfix, posted on Dec 03, 2007
The dryer was working, but stopped and the clothes in the dryer were still wet. I tried the circuit breaker but that wasn't the problem. I unplugged the dryer still nothing once I plugged it back in.
Solution #1
posted on Jul 18, 2008
Not Rated (0)
phreakiphred
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Check thermal fuse
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dryer suddenly stopped - F&P ED56 Autosensing Dryer:
I don't want to Accept this solution
Solution #2
posted on Apr 07, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I have a Frigidaire Gallery model GLER341AS2.It was working fine this morning and I tried to use it tonight and it will not do anything.The light inside does come on but when I push the start button there is nothing,no sound,nothing at all.Please help.Thanks.
Thank You!
Solution #3
posted on Jan 29, 2008
Not Rated (0)
Jerry57
Rating: 0%, 0 votes
I just repaired my Asko Dryer and mine made the squeek and the drum quit.
I replaced the belt. I took the dryer down. I got a copy of the repair manuel. I ordered the new belt as the old belt was at the bottom of the dryer. I put the new belt on and off I went. It has been working with the new belt for the past 3 months. The old belt was 5 years old. How did I get a copy of the parts list? Google. How did I get a copy of the schematics? Friend. Oh, It did not do anything when the belt broke. All went blank except for the red LED that showed that I had power. I checked the circuit breaker first. I opened the front to see if there were any broken parts. I cleaned the inside and all around the drum with a vacuum cleaner extension.
Thank You!
Solution #4
posted on Sep 10, 2007
Not Rated (0)
kstfas
Rank:Guru Guru
Rating: 85%, 144 votes
Check the house circuit breaker to make sure it isn't the problem first. It will be a two pole breaker probably 30 amp. Turn it all the way off and back on. if this doesn't work, refer back to previous solution. Good Luck.
kstfas
Comment by kstfas, posted on Oct 01, 2007
Did you get your dryer working? What was the problem with it?
Thanks,
kstfas
Thank You!
Solution #5
posted on Sep 09, 2007
Not Rated (0)
JPsAppliance
Rank:Guru Guru
Rating: 88%, 56 votes
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Thank You!
Can you Help with these Dryers problems?
Dryers
dryer will not turn on. just stopped working
Dryers
got ahotpoint tumble dryer aquarius model vtd60 and...
Dryers
i don't have a manual and cannot solve the problem - miele...
Dryers
i have a crosley cde6500w dryer - it was working fine -...
we have cleaned out all lint and exhaust is clear. it...
8 Other Users Have The Same Problem - Continued
Comment by naomimlr, posted on Nov 25, 2007
Dryer stopped in middle of cycle. Drum does not spin. Recently dryer has made a squeaking noice when the drum turned over. Does it need a new belt?
Comment by WaqarMehmood, posted on Nov 21, 2007
my whrilpool accudry dryer suddenly stopped and now doesn't turn on. where is the fuse for this dryer. I have opened the back panel of the dryer but don't see any fuse. can you help please.
thanks,
waqar
Comment by Guest, posted on Nov 14, 2007
Same problem No lights or power. I turned the circuit breaker on and off, and still nothing.
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
