Question about Sharp Viewcam VL-NZ100U Mini DV Digital Camcorder
No power My son knocked over my mini dv camcorder while he was taping himself skateboarding, and it won't turn on. I removed the batteries and re-installed them but it's still dead. I've tried ejecting the tape but it won't come out what can I do.
    Problem Solver:
  • 10 Answers
I would say its broken
Posted on Jul 09, 2010
  • 62 Answers
He has knocked the circuit board out of place. try unscrewing the screws and adjusting the circuit board
Posted on Apr 01, 2009
SOURCE:
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Canon MVX200i Mini DV Digital Camcorder: Remove the cassette
I got the same problem, does nobody has a solution. Please help!!
Eduard Mendlik
Jan 01, 2010 | Canon MVX200i Mini DV Digital Camcorder
What does this mean c;31;23
The camcorder has detected an issue that may require a power reset.
To perform power reset:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
If the issue still persits try with different media.
Aug 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
When I put the tape in, the tape does not slide down as it is and the door close. The screen display shows C:32:11. I do not know what that means. Thank you!
To power reset,
Aug 02, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
My JVC GR-D77OU Mini DV Digital Camcorder is giving me the next messages: eject en reinsert tape. unit in safeguard mode. After ejectirn and reinserting the video tape it still does the samething. I have...
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Jun 13, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Sharp Viewcam VL-NZ100U Mini DV Digital Camcorder Logo
102 people viewed this question
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
