Question about RCA Lyra M1001GBUS (1GB) MP3 Player
It wont turn on
I have been trying to turn on my mp3 player for a month.i let it charge untill it was complete,but when i tried to turn it on, it wouldnt turn on
5 Suggested Answers
SOURCE: mp3 player
Posted on Dec 27, 2007
  • 8596 Answers
SOURCE: my pearl mp3 player says no files when i turn it on
The songs are in the wrong format - it does not recognize iTunes songs or DRM-encrypted songs which do not have "transfer rights" (many msuic services - especially free ones but also paid ones - give you WMA's that have "play rights" -i.e. you can play them on your computer; but if they do not have transfer rights, they will show up in your player, yet not play correctly/skip).
Transfer only songs that are in Mp3 Format and you will never have this problem.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
SOURCE: My son listened to his mp3 player last night.
You can try to plug it into a wall plug using the charger that should have come with the mp3
Posted on Jun 28, 2009
SOURCE: it started with my mp3 player getting stuck at
did you hit the device by chance, or some hard shock. if that is/was the case, the lcd cable could have been dislodged. Not thing easy to fix on such a small device, however you can have a technician take a look at that aspect of it.
Another thing might be the backlight for the device is done with. not sure they are replaceable on those small device.
Posted on Aug 17, 2009
  • 133 Answers
SOURCE: RCA M4304 mp3 player wont charge even when plugged in
As long as your computer can see the player, it is likely the firmware has gotten corruped.
First, connect your player and back up any important media items that are on it.
Next, download and run the firmware installer from the RCA website:
Posted on Nov 19, 2009
0 characters
1 Points
Wont charge battery
Have you tried using another charger?
May 28, 2010 | Sony NWZ-E436F MP3 Player
The mp3 player wont charge. plug into computer and it shows charging but as soon as it is disconnected it shuts off and wont turn on.
Some mp3's don't expressly charge on the computer, that why when you connect it, the computer only sees it as a flash but is not actually charging it all this while and the battery is completely down. So try and get an external charger for it, the battery may be completely dead.Or probably you need to change the battery. Hope that puts a smile on your face.
Feb 04, 2010 | Samsung YP-K5 MP3 Player
My coby mp3 player is completly dead and will not turn on when charged up or reseted
how do you try to tourn it on try charging it to a point to where it wont even do anything and then try it
Jun 01, 2009 | Coby MP-C7085 MP3 Player
M mp3 wont turn on!!! :(
You can try a reset by doing this: Slide the power button up for approximately 15 seconds, which is basically like a complete power down of your device. Once you do the reset, it should work like normaly, but the adjustments you made during the last operation of the player will be gone.
Apr 06, 2009 | SanDisk Sansa Clip MP3 Player
Won't turn on
have you tryed sliding the power button until it turns on.. are you absolutly sure you charged it completly.. it takes 3hr to charge for comp.
Jul 21, 2008 | Insignia Sport MP3 Player
My creative zen is completely dead it doesn't power on at all also it doesn't charge there is no power what so ever please help me
I have had the problem of the completely dead player after having it for less that an day. No response to any buttons, no response when plugged into USB to charge, and Windows sees it as an "unknown device" when plugged into the PC. It tried the reset hole, and still nothing.
Then I tried connecting it to the PC to charge and then using the reset hole. Success - the player sprang back to life, fully charged. Hope this helps someone.
Jul 17, 2008 | Creative Labs Zen Stone Plus MP3 Player
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 23, 2008 | Philips SA5125/37 MP3 Player
My laser mp3 player
i have the same problem,
it turns on when i plug the usb cable in.
What should i do?
It's only 3 months old and all of a sudden it's just gone flat and wont charge
Feb 16, 2008 | MP3 & Digital Media Players
Wont connect to my computer
If it still has power, or charges, plug in the mp3 player then turn it on, then turn it off by holding the power button, once it is off, switch the hold on then press and hold the REC button until a black screen turns on saying that it is connected, your PC should then recognize the mp3 player as 16mb removable device, now open notepad, DO NOT WRITE ANYTHING on the notepad and save it as format.fmt and save it into the mp3 player and then safely remove it, the mp3 player should format. If the above does not work please reply with what you see inside the 16mb drive.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Black screen
i dont know what the problem might be but u should try calling sandisk they should know what to do. hope it helps
Jul 11, 2007 | SanDisk Sansa e250 MP3 Player
RCA Lyra M1001GBUS (1GB) MP3 Player Logo
22 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
