Question about Samsung HLP4663W 46" Rear Projection HDTV
Picture in Picture
I want to watch two cable channels with 'picture in picture' mode but the only source avalible is 'TV' on the picture menu. How can I fix the problem or how can I make componet 1&2 source options?
  • Anonymous Dec 06, 2007
    Totally have the same problem any help would be greatly appriciated
    Genius:
  • 1,694 Answers
Hook-up from HD Cable box component out to component in
on TV........Consult owners manual for workable options....T.
Posted on Dec 17, 2007
Why can't I see the picture when watching VHS movie?
Check the interconnection cable. Try a new one. Check whether proper source i selected with TV. Check whether both VHS and TV powered ON. Gopakumar Gopalan Google
Aug 09, 2014 | Zenith Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Dec 30, 2010 | Curtis LCD2424A 24 in. LCD HDTV
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
When I try to set our TV to locate digital channels, the menu skips the channel selection when I scroll through options of picture, audio, channel, lock, setup. All the options are available.
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 27, 2009 | Televison & Video
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
May 25, 2008 | Televison & Video
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
