Samsung 50" Slim-Depth DLP HDTV Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung DLP Horizontal Lines and Scrambled Colors
I have 2 pictures I can email to whomever would like to help me. Bascially the screen is flickering a lot and there are horizontal bars across the tv. There also seems to be a shadow effect. For example when a person is off the screen the shadow remains for a few seconds. I have unhooked everything to help diagnose the problem. When using a Play Station 3. You can still see the horizontal lines but the picture is 99% better. When using a Wii the problem is just as bad if not worse then watching regular tv.
So the problem remains on the TV when watching normal tv. Better when PS3 hooked to it, and worse when Wii hooked up. Any ideas whatsoever?
Anonymous
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Apr 18, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
58
Questions
0
Helped
33523
Points
127
I would like to see the pictures
thanks
1helpful
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
1helpful
Samsung HLP5063W 51 inch DLP is 4 years old. Screen scrambled?
there is a complete section in the tv that translate the different resolutions from the different out side video sources you normally use to the TV native resolution. That area has to be replaced. Is a module repair needed. Don't get scare. now days this kind of repair is normal and has to be included in the repair price to see if is economical to repair.
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
1helpful
2answers
Lines, colors, delayed images
Had the same problems.  This was after the a power outage.  Had green vertical and horizontal lines, like a checkered shirt.  But I searched online and found the simplest solution.  Just unplug the power.  And it worked.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
