Motherboard i know need to know how to insert and secure a motherboard in a computer and what tool is to be used?
  • 1 more comment
  • Bruce Richar Jan 14, 2009
    Sure, a small tipped Philips screw driver "can" work, but it would be better to use a nut driver that fits that head, so far I haven't been able to find one. I think Lenovo needs to be able to supply this for people. A long shank nut driver would be the best tool to have, now try to locate one. If someone finds one please let me know about it.
  • samchipato Jan 29, 2009
    evo to casing connections.how do you connect the panel board .which pins are for power,reset,hdd,and or power
  • Anonymous Mar 01, 2009
    does any1 know how to wire up a acer veriton 5200 motherboard to antother pc??? pls tell
SIR I HAVE XL 2000 MOTHER BOARD I WANT TO KNOW ABOUT THE RAM AND PROSESSOR RANGE UPTO
Posted on Jun 29, 2009
    Problem Solver:
  • 15 Answers
You will need some brass Studs http://www.frozencpu.com/products/3482/scr-39/Brass_Stud_Coarse_Thread_and91161_0505.html?tl=g4c157&id=5d2SykjZ An screws http://www.frozencpu.com/products/3492/scr-49/6X6MM_Hex_Head_Screw_Coarse_161_0292.html?tl=g4c157s329 Just a screw driver will secure those.
Posted on Sep 09, 2007
SOURCE:
No signal monitor and keyboard
desktop or laptop computer ?
if it a desktop
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines or a can of compressed air.
dust causes static which causes lots of problems with a computer and its parts
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the batteries are fully charged and have good seating points (if applicable) corrosion
make sure the ps2 lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 01, 2012 | ASUS P4VP-MX Motherboard
Al iniciar o reiniciar con teclado conectado aparece
google translate
When you start or restart with keyboard attached display
hope this helps
Aug 01, 2012 | MSI P4M900M-L Motherboard
Artista 200 flash drive not recognized
for xp operating system
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 22, 2012 | Bernina artista 200
Computer turns on but no signal & keyboard lights flashing
make sure the keyboard lead connection is secure and dust free (if applicable)
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
hope this helps
Jun 14, 2012 | Dell Dimension C521 PC Desktop
Nothing happens when I insert the memory card into the port, no instructions
if you are referring to a usb drive
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 27, 2012 | SanDisk 2GB Memory Stick Micro M2 Memory...
Keyboard not response
laptop or desktop
make sure the lead connection is secure and dust free (if applicable)
hope this helps you
Apr 17, 2012 | Shuttle AB60N 865PE Motherboard
My keyboard is not working
blow out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
click start control panel administration tools computer management device manager scroll to keyboards you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
or if this fails to fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
hope this helps
Sep 21, 2011 | Intel Desktop Board CA810E Motherboard
My motherboard doesnt detect ps2 keyboard, i just tried to clear cmos but nothing changed, i have the error 085, mother asrock 775i65g i tried to use a usb keyboard but nothing changed nothing in the...
click start control panel administration tools computer management device manager scroll to keyboards you might see a yellow exclamation or question mark or red x you will need to update driver right click to update driver
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
if you need more help with this post a reply
hope this helps you
Aug 24, 2011 | Asrock 775i65GV Motherboard
I get ''Failed Memory test'' at startup after installing maximum 2048MB of memory secured from Crucial after running their scanning tool before purchase. What do I need to do to get this memory recognized...
If you purchased more than one stick of RAM, just insert one of them, and try to start your computer. If you get the error-message, you have identified a "bad" stick of RAM. Contact CRUCIAL, and they will replace it. If no error-message, repeat with each other stick of RAM.
Jul 18, 2010 | ASUS P4B533 Motherboard
Unable to locate computer filename
hello
which operating system you are using, please let me know.
Thankyou
May 10, 2008 | ASUS P4GE-MX Motherboard
Computers & Internet Logo
492 people viewed this question
Ekse
Alun Cox
