Question about Samsung SC-D353 Mini DV Digital Camcorder
LCD I now have vertical lines on the LCD screen, though I still have sound from the tape. I cannot get the pictures from the memorey strip either. Before this I had watched some of the tape and it was fine. Then when I started it again The screen was clear,but I had sound. now it's the vertical lines. Is there something I can do about it?
Re: LCD - Samsung SC-D353 Mini DV Digital Camcorder Video Cameras
I am having the same issue as well.
Posted on Dec 25, 2007
I'm having the same problem
Posted on Dec 13, 2007
0 characters
3 Points
While video taping my sons game today the video randomly went blurry and there is a vertical line going across the screen what is this caused by and how do we fix it
This sounds like an internal issue. I can first recommend to confirm your camera is in AUTO mode. Second, i would see if those lines show up if you connect camera to TV. If it does, there is an issue with optical of camera, if it doesnt, might an issue with LCD screen
Oct 09, 2014 | JVC Everio GZ-MG130 Camcorder
Not able to view anything on screen
I work on this model of samsung the lcd problem is a common thing with this camera
The ribbon cable to the lcd from the camera cracks and causes what you are talking about .
Normally the camera will still work buy using the eye viewfinder for recording and playback but you will not hear the sound unless the lcd door is open but then the picture in the viewfinder goes away when this door is open and comes back when it is closed
my email is and sell on ebay as uromastyx
Jan 25, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
LCD shows stripes thus the picture is not complete
Mine was similar - with vertical black lines on playback. Visit, enter your make and model and ask for a head cleaner. They sent me one within 4 days and that was over the Christmas period. Reasonably priced too (£3.50 + p&p) and the whole head cleaner can be used up to twice once the tape has gone from beginning to end.
Jan 03, 2009 | JVC GR-D395 Mini DV Digital Camcorder
Vertical lines
If the lines appear on the tape this way when it is recorded, then the CCD unit is going out on the camcorder. If it isn't recording the lines then the viewfinder wiring or screen is damaged.
You should problably take it into a camera shop to see if its worth fixing.
Aug 13, 2008 | Canon MV700i Mini DV Digital Camcorder
Won't play tapes, just stays on the blue screen
ok. what you need to do it hit the side where the tape goes in...start out slow and then gradually hit harder and harder...not too hard though...because it sounds like a hardware need to unjam it by shaking it up a bit.
Jun 28, 2008 | Canon Elura 100 Mini DV Digital Camcorder
White screen on LCD and two vertical lines-1 red & 1 blue
Hi, check the lense. It might be dirty or you may have left the lense cover down.
hope this helps,
Dec 31, 2007 | JVC Everio GZ-MG130 Camcorder
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Split screen and blurred vertical lines in view finder and LCD
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (
Feb 11, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Vertical lines while recording Canon zr100 camcorder
I'm positive the camera needs to be cleaned. The recording heads sound like they are dirty and it doesn't matter what tape is placed in there, whether it's new or not. Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. The tape actually rubs the recording heads so you only want to do it for a short time to avoid damage. Let me know how it goes.
Nov 20, 2006 | Canon ZR100 Mini DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
73 people viewed this question
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
