Question about HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
I've had my HP Color LaserJet 2600n printer for a few months now and I've been experiencing a persistent problem with it. When it prints it frequently leaves a thin vertical white line an inch or so in from the left side. I've tried cleaning and recalibrating the machine several times and have replaced the toner cartridges but the problem persists. Any ideas what else I can do? Any assistance would be greatly appreciated. Cheers, Brett
    Novelist:
  • 217 Answers
A WHITE line usually has a particular cause.
Do a test print with a block of each colour CYAN, MAGENTA, YELLOW, BLACK in turn in the area where you see the white line.
The chances are that there will be a white line through just one of the colour blocks.
Remove the colour toner cartridge that is showing the white line.
Looking at the cartridge from the side that faces into the printer, it will seem to be noticeably in two halves, with a gap between. Look down that gap, and you will almost certainly see something that is obstructing the path of light from the laser unit to the drum of the cartridge. Carefully remove the object/debris, your problem will be solved.
IF the location of the WHITE line moves to different places across the page from time to time, you may have some sort of insect living in the printer. Strange, but I've seen it.
Posted on Sep 24, 2015
  • 83 Answers
Which color is this line? Try changing respective cartridge..
Posted on Sep 09, 2007
SOURCE:
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
How to set hp color laserjet cm 1017 mfp to print black and white
Open the Printers Properties, settings, select your print preference.
Jan 01, 2013 | HP Color LaserJet 2600n Printer
My HP laserjet color 2600n printerhas just started this and now prints with a thin black line on right of page and the colours seem all wrong can I fix it, I have proper HP toners in which are 3/4's used. ...
First try the printer self test as described in the instructions. Then delete the printer driver and reload it. Give the toner cartridges a series of light taps as well. This is about the limit of what you can do.
Jan 16, 2011 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 1600 printing 2 lines on paper, Uneven but straight.
If the line is one specific color, then change the corresponding toner cartridge. (You may be able to see the line on the drum in the toner cartridge.) If the line is a mix of colors, then it is probably either the transfer belt or the fuser. In either case, you could replace the whole printer for about the same cost as repair.
Apr 06, 2009 | HP Color LaserJet 2600n Printer
Printer is not working
try to unplug the printer from the wall and plug it back in.let me know how this works
Feb 13, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
Jul 21, 2008 | Sharp AR-5320 Black and White Copier
HP Color LaserJet 2600n Printer Logo
914 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
