Question about HP LaserJet 4L Printer
HP Laser Jet 4L - No Power
Printer suddenly stopped powering up. Checked cables & power cords and all is well on that end. Same issue came up about 8 months ago. At that time, I tried the same things I did this time, and figured it couldn't be fixed and wouldn't be worth it due to cost. The printer was still hooked up and about 2 mos after it stopped powering up I went to hold down the power button and it started working again with no problems until now. Any thoughts? Is there a part that needs replacing? I love this printer, since 1995, it has NEVER jammed on me even once.
  • 1 more comment
  • mylob Sep 14, 2008
    My 4L would not work after a power outage. I took it apart, cleaned the plug contacts and the fan and it still doesn't work. Anything else I can try?
    I just bought a nre toner cartridge and would love to get it working again. thanks
  • barrybrocket Mar 22, 2009
    Have two of the HP 4L printers, and suddenly one of them will not power up. Changed cords, same problem. Any assistance deeply appreciated.
    Barry
    West Covina, CA
  • barrybrocket May 11, 2010
    How do you clean the power switch? Where is it, that elongated button on top to print test pages?
  • 883 Answers
It's possible that the power switch alone just needs cleaning. Take it apart down to seeing the copper contacts and then polish the copper contacts with emory cloth.
Posted on Sep 09, 2007
I bought this printer the first day it became available, and it has been a great printer. I also use 2 Epsons for graphics. My 4L just stopped, no power, I cleaned the plug and it worked. I gess after all these years it needed claeaning. I sure hated the thought of getting rid of it, I just put a new cartgage in about a month ago.
Thanks for the tip.
Posted on Oct 10, 2007
5 Suggested Answers
SOURCE: on & off switch
There is no on or off switch. It works automatically. After print jobs are completed the unit turns off after a few minutes.
Posted on Feb 04, 2008
  • 138 Answers
SOURCE: HP Laser Jet 4L fuses
The fuses are located on the DC Controller (main bottom board). Getting to the DC Controller Board on a 4L printer is a very significant disassembly. Best left for a pro but if you really want to do it, I have attached below a link to a scanned copy of the service manual. Please keep in mind that the scanned copy is not a nice fresh PDF as most manuals as the 4L was made in 1994 and HP has physically scanned the printed manual for distribution. Just look up the removal and replacement of the DC Controller Board. Once removed, the fuses are glass buss style, readily available at any Radio Shack.
Gotta love that old technology.
Hope this helps you. :)
http://www.feedroller.com/Store/Service%20Manual/LASERJET%204L,%204ML,%204P,%204MP%20Service%20Manual.pdf
Posted on Sep 10, 2008
SOURCE: HP Laser Jet 4L jammed
Open rear cover. Press green release lever upward. Push paper backward (out of top toward back) When all paper out of upper roller, pull remaining paper straight back. It will move easily.
I'm sure this is too late for the original post, but it might help someone who comes along later (like me)
Posted on Jul 08, 2011
vinay229229
  • 1121 Answers
SOURCE: H P laser jet 4L will not turn on after a long
When its not using so many months,mechanical jam may occured, in this condition its draws more power when its switched on, fuse may blow off, check primary power section in power supply board, replace the fuse with same rating then try it...best of luck...OLD IS GOLD..
Posted on Sep 06, 2011
I just bought a Compaq Presario computer and need an adapter cable for my HP Laser jet 4L. Where can I find one?
The HP Laserjet 4L uses a standard 25pin parallel printer cable.
These can be purchased at your friendly computer shop or on the Internet.
Mar 29, 2010 | HP LaserJet 4L Printer
Need a power cord where can i get one
www.partsurfer.hp.com in the support section will have your ac adapter. The best price, right from the source.
Feb 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
HP 4L laser printer - no power indicators showing -
there is not a fuse in the printers main board but i can say that there is circuit breaker on the board like fuse only instead of fuse there is a ic that ic has to be replaced if major damage the cost may vary other wise the ic is just under 1$ THATS IS.IF ANY ENGINEER DOES HE WILL CHARGE HIS SERVICE FOR THAT.BUT CALLING A ENGINEER IS ADVISABLE AS HE WILL ALSO CHECK OUT ANY OTHER PART GOING TO BE SHORT IN NEAR BY COMING DAYS.
Mar 02, 2009 | HP LaserJet 4L Printer
Hp 2840 Laser Jet wil not power on
this sounds like a low voltage power supply issue. your low voltage is soley for powering up the machine
part number RH3-2260
Sep 29, 2008 | HP LaserJet 2840 All-In-One Printer
Hp laser jet 4L problem
try holding the "online" button down when turning on the printer release when you get "cold reset" message
Jun 26, 2008 | HP LaserJet 4 plus Printer
LASER JET 4L PRINTER PROBLEM
Dear pamswab.
there is an interrnal fuse in the printer you most open it and found the power bourd the fuse there
This is in reference to my relatively new HP laser jet 1018. it has suddenly stopped printing after a perfect record of a long time. all connections have been checked. is it possible that it needs a new...
TRy this....And let me know... ISSUE: The printer is in Ready mode, but nothing prints. SOLUTION:
  1. Restart the computer.
  2. Verify that all of the cables are properly seated and within specifications. This includes the USB, network, and power cables. Try a new cable.
  3. Reinstall the printer software. In the Windows task bar, click Start , Programs , HP , HP LaserJet 10xx series , and then click Uninstall HP LaserJet 10xx series . Turn the printer off. Install the printer software from the CD. Turn the printer back on.
  4. Close any applications that are running. To close an application that has an icon in the task bar, right-click the icon, and select Close or Disable .
Apr 04, 2008 | Office Equipment & Supplies
4L has died?
time to give it a decent burial..parts on those old 4L's are mostly drawn from others that are no longer functioning..
maybe you ought to have an HP wake, and a decent burial?
at any rate..that sounds like a power supply board went zonko..
Mar 21, 2008 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
2,188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
