Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Can't get Internet through my router.
I have a BEFSR41 Linksys router. Yesterday, my computer failed to connect to the Internet. I kept getting the "Page is not available" message. After contacting my ISP (Shaw Cable) and trying a number of unplugging steps and rebooting procedures, the issue was unresolved. It wasn't until I bypassed the router and plugged the modem directly into my computer that I was able to briefly connect to the Internet. Today, I contacted Linksys and told the technician that I was unable to get the IP Address through the router, as my ISP told me to say. Linksys wanted $30 to continueto help, so I said no and found this site on the Internet. Any help would be greatly appreciated. Dennis
  • Dennis Sep 11, 2007
    I don't know why this worked this time, because I had tried the suggested hookup and wait time a few times already.
    I'm not looking a gift horse in the mouth, however.
    Thank you exnavydavey for taking the time to address this problem of mine.
    Scholar:
  • 47 Answers
Ok, first... hook up your router to your modem. Go and get a drink and chill out for 15 minutes or so... that'll give their network time to realize your MAC Address has changed. If it doesn't work, bring up your browser and type 192.168.1.1 (could be 192.168.0.1 as well) in your Address bar. The default login is usually "admin" (sometimes Linksys leaves the User field blank too) and the default password is "password". Check the status page for a WAN IP Address, if you have one contact Shaw Cable and get them to check to see if they can "ping" it (they'll know what that means). If you don't have an IP Address, you may have to use PPPoE to authenticate your account... verify that with Shaw as well. If it's PPPoE, then you should have a username and password that they have assigned to you. If the first line person can't help you, don't let it go... get them to get a Tier 2 or 3 person on the line.
Posted on Sep 09, 2007
  • David Sep 11, 2007
    The wait time is to allow the MAC address of your router to propogate to the rest of the servers in their network. Typically, router tables (./etc/hosts) files are only mirrored to other servers at specific intervals. So if you catch it just after the last cycle, it may take longer until it begins again.
SOURCE:
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
MY Internet Connection is good but when I run it to the BEFSR41 V.4.3 Router ANd try to run the setup disk it caomes back unable to find internet connection. I have tried to reset the modum and router to...
Well there might be bug in the CD. sometimes it shows that the internet is not working.
You can set up your router manually without the CD.
If you connect the computer to the modem, it works . right ?
Now connect the modem and the computer to the router.
Reset the router for 30 seconds. Unplug the power to the router. plug it back in.
Wait for a minute and reconfigure the router manually.
Click Here for more info about how to set up router manually.
Nov 28, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Linksys Rouer BFR stops functioning
There's a possibility that the router is already going bad but you can try first updating the firmware of the router because sometimes this problem is related to the software of the router so you may need to update its firmware,but if still after updating and still the same a new router will be the best solution for this problem of yours..You can also call this number for technical support help and double checking if the router is bad or still can be fix 1-877-787-8749...
Don't forget to rate the solution FIXYA thank you....
Oct 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
225 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
