Home | Mitsubishi | WS-65807 65 in. Rear Projection Television | MY TV COLOS GO AWAY GOE...
Mitsubishi WS-65807 65 in. Rear Projection Television
Problem for Mitsubishi WS-65807 65 in. Rear Projection Television
MY TV COLOS GO AWAY GOES DARK CLOUDY KIND OF GRAYISH
By churro0835 on Apr 10, 2009
MY TV IS LOOSING IT COLORS SOMTIMES I HAVE TO TURN IT OFF FOR FEW MINUTES THEN TURN IT ON BIT IT KEEPS HAPPENING WHAT TO DO?
Solution #1
posted on Apr 10, 2009
Not Rated)
jgwhomeequip
Rank: Guru
Rating: 86%, 748 votes
Check your color wheel sounds like that is going bad. 90% of the time the color wheel is the culprit in this cause. You will need to remove the back panel to get the to color wheel. You will see 7 different plastic adjustments. You can also order this part online at mitsubishis website
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65807 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65807 65 in.
Do you recommend Mitsubishi WS-65807 65 in. Rear Projection Television?
Answer
Answer
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up.... (More)
Answer
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just... (More)
Answer
We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden.... (More)
Answer
we have a mitsubishi HD 1080 series rear projection tv made in fall of 2000. the DVD player thru... (More)
Answer
I want to know how to fix my WS-65807 tv, but can't seem to figure out what to change and where it... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65807 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
