I have a 6-month old ESP8XL Espresso machine that starts off fine but then makes loud popping noises followed by large bursts of steam. Almost like explosions of steam. It's quite disconcerting so we stopped using the machine. Any suggestions on what the problem might be would be very much appreciated. Thanks.
the machine is building too much steam so the safety is blowing off, there might be a thermostat on the machine that is not telling the elements to turn off at the correct temperature. Use ohms meter to check thermostats.
Have you checked to see if the silicone ring that the filter tops out against is cracked? It could also be a crack in the black plastic filter holder ring, allowing the filter to separate from the silicone seal. The seal and the filter ring can both be replaced. Write to your local Breville to get the silicone ring or a replacement plastic filter holder. You can also purchase replacement ring in aluminum for about $50 at http://www.vancouverwireedm.com/caferomadiyt.htm .
the little part were the cofee comes out from is clogged and the water and coffe comes out of the...
(More)
the little part were the cofee comes out from is clogged and the water and coffe comes out of the sides what can I do?
