Question about EliteGroup (ECS 915PL-A2) Motherboard
I'm not getting a picture when I turn on the computer.
Hey everyone. I'm having a problem with my EliteGroup 915PL-A2 Motherboard... I'm turning on my computer, and I have the graphics card hooked up, and the Monitor is plugged in, but I'm not getting a picture... Can anyone help me?
  • 6 more comments
  • xxmaddgoodxx Sep 15, 2007
    how can i install it if i cant see whats going on on the screen?
  • xxmaddgoodxx Sep 16, 2007
    so wait.... i need an elite group graphics card for an elite group motherboard?
  • Anonymous Dec 29, 2007
    the word are not cleear enough to see
  • bthecarebear Jan 07, 2008
    I have just recently bought the same motherboard. There is NO onboard graphics. I was using and older PCIe card and also a new 8800. The computer boots fine, but it produces no picture. I have tried the RAM in each slot and still no picture. I have also tried both VGA and DVI on two different monitors. This motherboard has been nothing but a pain...please help!
  • Justin95623 Jan 09, 2008
    same problem here im using same motherboard with 1 gb ddr 400 pc 3200 ram and an intel celeron D 360 3.46 processor and the graphics card is a GeForce 7300 gs and a 500 w power supply.. no hard drive or opperating system installed yet because i cant see anything...HELP
  • Debijesse Mar 23, 2008
    no video. turn on the cpu, can hear fans and see power switch lit up. Just no video. Computer came to me because they could not boot up.
  • Anonymous Apr 02, 2008
    I have the same problem... When turn on computer, CPU fan starts working, LED1 on MB is turned on, but I have no picture on screen...
    MB - ECS K7VZA
    Graphic card - ATi Radeon 9550SE 128MB AGP
    Processor - AMD Duron 1300MHz
  • wyjadecho Aug 23, 2008
    i switched on the tower and it turned on normal but when i switched on the monitor, there's no picture, ie, the monitor stays black. Why?
Ok. This may not have anything to do with your video card at all, as people keep suggesting.
There are two RAM slots on this board. How many sticks of memory are you using, what are the specs on them? And if you are using two, are they dual channel?
This board, I BELIEVE, requires dual channel memory. If you are using two different make in chips, or two different sizes, it may not boot. Also, since it requires dual channel memory, if you're only using one stick, you may have it in the wrong one (some ECS boards are like this). If that's the case, try switching the single stick to the other slot and see if it boots up then.
Posted on Dec 16, 2007
I have the same problem but on a PT880PRO-A, no post, no video, fans working, leds light up, no beep sounds even with out ram, tested psu and evreything else with another pc and works, all testted but not the motherboard, bios batery changed, tryed diferent video cards that do work, the last thing is a dead bios, so i'am thinking about a hot flash to the bios chip, as a last resource, before i buy a new motherboard.
did i mention there is no onboard video.
Posted on Sep 23, 2008
I have no video using a pci vodoo card and a 360 celero 533fsb looks like on the box it ony supports o4b and o4a processors.
Posted on Feb 21, 2008
    Sergeant:
  • 201 Answers
I realize the post is old but I have the same mobo. The deal is that there are two PCIe slots on the board that can allow for crossfire connections.with Scalable D.G.E. The most obvious solution is to ensure you have the video card in the slot closest to the cpu. The other responders seemed to be unaware of the fact as well that there is no onboard video. Also ensure you have the second power connection to the motherboard plugged in. It is near the PCI slots. Without it the mobo may be unstable. There is also caution about using a PSU with 20 rather 24 pin connection, even though they provide the option. Hey this post may be to late to help you, but there always a newbie around every corner. Happy Computing!
Posted on Jan 27, 2008
  • Devocap
    Devocap Jan 31, 2008
    Hey there, can you please tell me which Videocard and model you are using. Is it Crossfire compatible? Also if you can elaborate on the processor you have installed. Is power going to the board? Are any lights flashing? Are the fans working?
    Scholar:
  • 103 Answers
First off, this MB does not have an onboard video/graphics card. SO there is nothing to disable in the bios.
However, no one has mentioned what video or graphics card they have tried to install. OK xxmaddgoodxx did mention a nVIDIA 7600gt, but failed to state whether it was AGP or PCIe and what connectors the card supports. If either of the users having problems with this MB are trying to install an older video or graphics card it is not going to work. This MB uses a PCIe interface for video, and depending on the video card, you will have either a 24 pin DVI-I port and/or an S-Video/TV-Out port and/or a standard VGA port.
I hope this helps to clear up any confusion.
Posted on Dec 15, 2007
    Champion:
  • 238 Answers
Hey buddy , if ur using an addon graphics card, you first need to disable the onboard display in the bios, try and let me now
  • 91 Answers
Yeh the problem is is that you need to install the drivers for the videocard with your monitors brandname your video card might not be picking up your monitor
Posted on Sep 10, 2007
  • kimberly puddicombe Sep 16, 2007
    have you tried referring to the manual the manual might have the solutions that you are looking for
  • kimberly puddicombe Sep 27, 2007
    nowadays the graphics card is built onto the motherboard just go to www.yahoo.ca type in the name of the motherboard and it might give the name of the graphic cards
SOURCE:
Describe your (ECS 915PL-A2) Motherboard Problem do not detect hard disk and dvd rider in the bios
1. Check if both drive data and power cables are correctly and tight fitted.
2. If both are fitted on PATA (IDE) on the same port/cable:
The harddisk should be the MASTER and DVD the SLAVE device.
3. Recheck.
4. If not OK, Power OFF the computer (also from the wall outlet).
5. Place the mainboard jumper for CMOS RESET to the other position for a few seconds and place it back.
6. Turn the computer Power ON and check.
Aug 25, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
I cannot find any sound driver for my pc....please help me
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
Apr 16, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
Cannot find the SATA hard drives for my ecs 915PL-A2 mother board. All connections have been checked
Did it just stop? Or is the a new system?
Did you check your BIOS settings?
ECS is not known for excellent quality - if you have a bad board hopefully it is still under warranty.
Mar 04, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
No power
Make sure the cpu fan is properly placed on the processor or not !!! It might cause the problem..
Thank you......
Oct 09, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
No Video!
Have you tried a CMOS reset (sorry if this seems obvious, but I'm just making sure)?
Jan 07, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
ECS 915PL-A2 motherboard RAM upgrade
try to reset the cmos first so that the bios would refresh
Dec 23, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post, no video
get some cheap PCI card plug it in. get to the bios make sure integrated video is selected. Speaker connector is two pins in various motherboard the pins should be located close to the reset and power pins.
Oct 26, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post beep, no video
had a similar problem with a box i built. Your power supply has two connectors. One long one and a 4 pin connector. Make sure that four pin connector is connected.
Oct 25, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Ecs 915pl-a2 v3.1b
Check this out http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Specification&MenuID=44&LanID=0
Oct 19, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Open Questions:
See all EliteGroup (ECS 915PL-A2) Motherboard Questions
EliteGroup (ECS 915PL-A2) Motherboard Logo
1,284 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
