RIM BlackBerry? Curve 8330 Cellular Phone Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SanDisk 2GB memory card
I have a Blackberry 8310 phone and I bought a SanDisk 2GB memory card. I put it in and it it says "Media Card cannot be read. Verify that the memory card is formatted." So I went to options and selected Media Card, then I clicked the menu button and selected "Format Card." I waited for more than 10 minutes and nothing happened, my phone froze up...I couldnt scroll to select anything with the tracking ball. So I took out the battery and memory card, and put the battery back in to restart my phone, to get it to work again.
What should I do to get my memory card formatted correctly and working?
Anonymous
Level 2:
  • Expert 137 Answers
  • Posted on Apr 10, 2009
Anonymous
Expert
Level 2:
Answers
137
Questions
0
Helped
51487
Points
288
Format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
1 Related Answer
Anonymous
  • 173 Answers
  • Posted on May 13, 2009
SOURCE: Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
When i put my sandisk into my blackberry phone it keeps saying a media card has been inserted that contains errors. to correct the errors please use a disk error-checking utility on a computer . how do...
Put the SanDisk into your SideKick phone, and navigate through the menu-items to "format" the device, i.e., delete all pictures, and return to "factory-shipped" condition. Then, put it into your B.B., and repeat the "format" process, to be 100% "factory-setttings".
I have a 2GB micro sd card for my blackberry when i put it in. It says media card has inserted contains errors. yo correctthe errors use a disk error-checking utility on a computer. what do i need to do?
if this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
The sandisk stop working on my blackberry 8310
simple this may occur due to a virus so what you need to do is to format the memory card
Media card
If you inserted your sd card corectly, you should be able to save items to it as long as it is not a defective unit. Do the following:
1) From the Home Screen Menu, go to Settings, then Options, and scroll down to Media Card and choose it with the trackball.
2) From there you will see the Media Card configuration options which allow you to set the Media Card Support, as well as the Mass Storage Support option. Also, you will be able to confirm from this screen if the phone is recognizing the presence of your sd card. Hope this helps.
1helpful
SanDisk 2GB microSD not working on BBerry Curve
Two options--Go to Options > Media Card, set Auto Enable Mass Storage Mode When Connected to Yes.Another one go to this site http://forums.pinstack.com/f8/mass_storage_issues_heres_the_fix-96938 and on the first post there is a file "BB storage Activation new.rar" of size 3.63 Mb.Download it,extract it and upload it on your phone and just install.It will definitely solve your problems.Also you need to register there to download that file...just do it no problem.
Format sd memory card 2g for blackberry usage
Dear,
Just format the card using PC. It is very simple. Right click on drive(card) and select format. It is ready to use.
Regards,
Rakesh Kumar
Media card insert
you need to format the card. Go to options, scroll down to "media card". Click on this, when it opens, make sure media card support is "on", .......make sure Mass storage support is "on" Then click on "Menu" which brings up the option to "Format card" Then cliuck on this option and it should be OK,
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
http://demos.blackberry.com/8310/na/us/gen/
Good luck
1helpful
Cannot add music onto blackberry curve 8310 with sandisk 1 gb memory card
pls format the card from the blackberry device.
this should take care of the issue
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
