Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Green screen on HD channels
When I watch HD channels I get a green screen, but the audio works fine. Same thing with the Xbox 360.
  • 1 more comment
  • Anonymous Nov 19, 2007
    i have a similar issue. I have verizon fios and I had attributed it to their new programming update or the dvr i have, but now I am not sure. Intermittently my HD channels turn "green" its as if there is too much GREEN in the feed. Any help would be appreciated. I am about to take it back to best buy, thanks
  • CYPHAZ_KID Nov 26, 2007
    the xbox was working fine 4 the first couple of days until i shut the xbox down i got a green screen of death the audio works i can change the channels and turn off the direct tv cable box only the regual tv works
    im 15 years old my mom and dad wont be to pleased with what they discorver ..............HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Dec 03, 2008
    When playing a DVD on the HDMI cable get a green screen can see dvd but in green
VIDEO CARD IN LCD IS BAD MOST CAUSE OF THIS PROBLEM
Posted on Sep 23, 2007
SOURCE:
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
My xbox 360 dosent give video
Plug in the Yellow A/V connection to your TV's Video input. or if you have the HD cable you have to have the Green, Blue, Red, pluged in to get video, and then the White and Red for the Audio. (HD cable will not work at all on a A/V input on a TV.) HD cables have 2 red plugs, 1 is for audio, and the other is for video, they should be labeled to tell you what one is what, but if they are not, if you flaten the cords, the Audo White plug will separate the 2 reds, and the one that is between the White and either the Green or Blue plug is the other video.
If thats not it, I couldnt tell you, unless you have a bad connection on the back of your 360, or just a bad xbox.
Mar 09, 2010 | Microsoft Xbox 360 Console
Screen turns green and red lines appear across
my HD LCD used to turn grey on my 360 so i just turned it off then back on for the results but of coures it could be the LCD is dying
Dec 28, 2009 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
ANOTHER BROKEN XBOX 360
replace heat pads they are so cheap. wrap pennies in electrical tape and put it on were the heat pads were. use Heat Sink to glue it on
Oct 01, 2009 | Microsoft Video Game Consoles & Games
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Whats Wrong With My Xbox 360?
it has to be on the wrong plug in ins or on HDTV. if you need more help my email is: [email protected] i got one on christmas to i sorta like SOFTLY boped it and it booted up. sorry bout it
Dec 27, 2008 | Microsoft Xbox 360 Elite Console
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
519 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
