Question about Haier HTF20R21 20" TV
Remote codes I cannot find any remote codes to enable my Comcast cable remote to operate my haier tv
  • lildarlun Dec 08, 2007
    I put the remote codes for my Envision L32w698 into my comcast remote and does not work
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
  • 3 Answers
Tell your local comcast office there to give you one of the remotes that has a red ok button on it. That remote will work with haier tv's. They take 5 digit codes and for haier tv's the codes are 11034, and 10768. You simply press tv then hold down on the setup button and enter one of those two codes. One should work.
Posted on Oct 15, 2007
I called Haier and was told their TV's do not work with any other remote other than one that is supplied so universal and satellite remotes are out. Not a good company to choose for the way technology is headed and will be gone before long if they do not get with it.
Posted on Sep 30, 2007
    New Friend:
We have a haier TV HTR-022
we forget the code of the remote control if u have solving our problem with best regards
bedar
Posted on Jul 13, 2010
I encontered the same problem with my old 13" Haier tv i bought back in 2001. I bought a Radio Shack Family Favorite 5-in-1 remote for $14.99 since it was the only one that listed Haier. That code was 1034. Try that.
That didnt work for me unfortunately, so I referred to a combination of the troubleshooting of the 2 previous models (4-in1 and 3-in-1).
1. Press "TV" button
2. Hold "P" (program button) till the "TV" button flashes once then twice
3. Enter 9 9 1, and the "TV" should flash twice
4. Aim the remote at the TV and hold the Power button down for at least 3 seconds. (Remote automatically goes to first code but it probably wont work so go on to step 5)
5. Press CH+ repeatedly till the TV shuts off and stop immediately!
6. Hold "P" for 2 seconds
7. Hold "Select" for 2 seconds
8. Hold "P" for 2 seconds
9. Hold Power for 2 seconds and TV should turn back on.
If not. Repeat steps 1 thru 9. I know it sounds tedious but its the best bet. It took me three tries because my finger slipped and hit other buttons or I didnt stop when it shut off. I spent 3 hours looking for codes online and nothing worked.
Replacement on the Haier website is $19.99 plus a load in shipping. This beats that!
Good Luck!
Posted on Jul 23, 2009
3 Suggested Answers
SOURCE:
SOURCE: remote codes
Comcast remote codes for your TV. 11034 or 10768
Posted on Jan 21, 2008
  • 43 Answers
Most remotes have a "Search for Code" or learn function. However, since Comcast currently supports 8 different types of remote controls, your best bet is their website. This link takes you to all of the remotes they currently support, find your remote and click on the View Manual link next to it.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
More than likely you will have to use the "Search for Code" option, as I did not see your particular TV brand on the few that I checked.
Posted on May 30, 2008
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
I have an haier model L32R1 and comcast cable just came to install and the comcast remote will not work can you tell me what the universal code is to get the remote to work.
i have the same problem and still looking for the code :( but for the mean time i just hook up my digital box to the tv threw the video inputs. hope this helps you.
Dec 03, 2009 | Haier HL32R 32 in. LCD TV
I have a haier tv with a comcast remote. Need the Haier code for the comcast remote
10768
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
May 28, 2009 | Haier HL42E LCD TV
Haier HD tv purchased
Problem has not be resolved, but after reading your response I understand that you are offering me help but at a cost., I find that unbelievable because I just purchased this TV haven't had it 2 weeks., and you can't even tell me if there any more codes to try and make my digital cable service remote work. If this is what you are telling me, then I will surely add my comments to your web site. Thanks for standing behind your product.
Dec 30, 2008 | Televison & Video
Remote codes
May 30, 2008 | Haier TN201AUV 20" TV
Remote codes
What is the Comcast remote code for ProView 3200 TV
Jan 06, 2008 | Haier AHD50 Dehumidifier
Remote codes
Jan 06, 2008 | Haier HTF27R11 27" TV
Haier HTF20R21 20" TV Logo
14,338 people viewed this question
Top Haier Televison & Video Experts
Eric Rotmil
Eric Rotmil
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
