Question about Toshiba 27AF42 27" TV
Zenith advanced system 3, can't access video 1 or 2
I have a zenith advanced system 3 that works fine, but unfortunately has no remote or service manual.. I wanna switch to video 1 to play my xbox but for some reason there doesn't seem to be a button to do it on the panels... Can anyone help me? How can i switch to video 1?
  • 3 more comments
  • Anonymous Dec 19, 2007
    same problem, maybe need remote?
  • Anonymous Jan 07, 2008
    Have the same problem as well.
  • Anonymous Jun 14, 2008
    Same problem. I have dead remote.
  • cdiggs Sep 21, 2008
    How do I access the video 1and 2 manuallly, there is no button for this on my unversal remote.
  • Anonymous Sep 23, 2008
    damn! same here!! somebody help
  • 4 Answers
I just got the TV for free with no remote and had the same problem.  The solution I found is to connect two devices that are feeding live signal (a VCR, DVD player, or game console) to the RCA connector input on the back of TV for Video 1 and Video 2.  I then used the first menu option which I accessed by using the Menu key on the front of the TV and Adjust and Select buttons to scan for channels and detect the band for the reciever to use.  After doing this I changed the setting away from "Fixed" (I forget which setting) and turned the TV on and off.  I then found that by pressing Menu several times I would get new menus.  Before I had done that scan with more devices attached to the other ports I didn't get any other menus.  I also discovered that depending on which devices I had connected I would get a Picture in Picture feature.  It would have its own menu to select its source, but I would lose that feature if I changed the device topography of my setup.
Posted on Jan 19, 2009
I read the posts above and then tried it and it didn't work. So I tried using a universal remote. I just found an extra DirecTV remote lying around and programmed it to the TV. I then just pressed menu, right, and my video was on the screen.
Posted on Jun 13, 2009
Maybe needs remote
Posted on Dec 19, 2007
  • 93 Answers
Is your tv has the a/v jack? if none you have to use the rf modulator.
Posted on Oct 26, 2007
Can i use an rca universal remote to use my older zenith advanced system 3 tv
You can if the RCA universal remote is compatible, i.e., contains the appropriate code.
Oct 12, 2017 | RCA Televison & Video
1997 Zenith tv, 27" i cannot find a remote or proper access code that will work on it.
Try out the Harmony remote - tad more expensive but very flexible and comprehensive.
Sep 06, 2017 | Zenith Televison & Video
I need a remote control, or need to know if my universal remote w
I just discovered this site because my remote just quit as well. Here is the direct link. http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6710CDAL01C/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=DVT412 Not bad price either.
Jan 20, 2009 | Zenith DVT412 System
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
www.universal.remote.net/zenith.html
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Remote Control codes -CL015 Zenith
sylvania tv codes are what you need try these 0062 0004 0009 0135 0189 0183 1141 0227 0456 0458 0008 0068 0075 0141 0161
Oct 29, 2007 | Radio Shack 3-in-1 Easy-to-Use Universal...
Zenith Advanced System 3 not working
your tv is in EYE PROTECTION MODE... NO JOKING... You might have damaged capacitors inside near the tv CPU and in the main power supply. Pleasecontact a good service tech for repair Patrick
Aug 27, 2007 | Televison & Video
Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Jun 30, 2006 | Zenith DVB412 DVD Player
Toshiba 27AF42 27" TV Logo
1,345 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
