Question about Samsung AW1293L Air Conditioner
Machine shuts off
My Samsung air conditioner will only run for about a minute after the compressor kicks in. After that, the entire unit shuts off. I can only restart using the remote control. Pressing the start button on the unit has no effect.
  • 60 Answers
Your control board assembly is faulty relace with a new one from your local appliance parts store
Posted on Sep 09, 2007
Do I need a new control panel if my compressor kicks off every 2 to 3 minutes?
check the outside unit is clear and has lots of air flow, try cleaning the outside with a garden hose, most likely the compressor is cutting out because it is getting too hot.
Jul 19, 2015 | Heating & Cooling
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Turn on unit starts blowing cold air for about 5 minutes the compressor kicks off. will not come back on. you can turn it off and back on and compressor will start back up again for about 5...
soulds like when it starts the high pressure switch kicks it out when you turn the power off you equalize the pressures check you coils and filter they need to be cleaned most likely this is the problem
Sep 11, 2010 | Comfort-Aire RAD-243 Air Conditioner
Compressor will cut on run a few minutes and shut off hot air
The compressor is probably going out on overload. There may be a small refrigerant leak thus making the compressor run hotter than usual. If there is not enough refrigerant in the system, the compressor will not get the refrigerant back to it to keep it cool. This is a safety feature built into the compressor to keep it from overheating and locking up. You may want to take it to your local appliance store and have it looked at. Most of the time it usually is cheaper to buy a new unit than to pay for just the labor to have them fixed.
Jun 07, 2010 | Samsung AW1203B Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Brand new Duo Therm won't stay running
You really need an Ammeter to check this problem. Just because it is a brand new unit does not mean that there isn't a problem with it. Is it run off of a wall thermostat or manual controls? The compressor has a thermal overload switch on the top (under the plastic cover) that will take the compressor out of the circuit if it gets too hot. However, if the entire unit is shutting off, there is another problem. Selector Switch? Thermostat? Let me know what kind of controls you have and we can go from there.
Jul 01, 2009 | Dometic Rooftop RV Air Conditioner
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Roof top motor home coleman air conditioning unit
What is outside (ambient) temperature. When was entire unit last cleaned? (evaporator coils, & condensor coils)
Jun 04, 2008 | Coleman Mach III Air Conditioner
Samsung AW1293L Air Conditioner Logo
474 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
