Question about JVC HD56FH96 56" Television
How to replace bulb on dlp JVC tv
The directions that came with the replacement bulb say I have to remove the left speaker panel, I can't figure out how to get it off!
    New Friend:
Message came up that said i needed to replace the lamp. is this correct or is there another fix for this message
Posted on Mar 19, 2011
SOURCE:
Where do the bulb go in the tv
If its a DLP TV on the rear of the is usually where they go..there is a small access door that you remove and behind that door is the bulb cage
Apr 18, 2013 | JVC HD-52FA97 HDTV
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
HOW DO I CHANGE THE BULB
Remove the center panel, on the front of the TV, next to control buttons. The rest is simple, although you will need a long neck philips screwdriver to get to the bulb once get the housing out.
Apr 02, 2010 | Panasonic PT-60LCX64 Television
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Describe how to replace bulb for magnavox hdtv #50ml6200d37
easy. pop off the front cover.. Start at the right edge. The front part that covers the speakers comes off as a complete cover. Then there is a square panel that must be removed on the left side front about three screws. once the panel is off there is three thumb screws .. loosen them.. they do not come out. then when they are loose pull on the panel handle and out comes the bulb unit. then follow the install instructions of the new bulb. Do not touch the bulb with your hands... It goes back the same way .. The exterior panel must be in place for the tv bulb to fire up..
Oct 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
I need to change a lamp
Looking at the TV.....You have to unscrew the left side speaker panel. Then you have to unscrew the black panel next to the speaker - this exposes the lamp housing. Unscrew the two small screws that hold the housing in place and gently pull the lamp housing out. Now you need to see if the bulb is defective or not. I've gone through 4 bulbs in 4 years so get use to it. You can get the bulb/housing units online cheaper then what a TV service will cost. Good luck!!!
Dec 23, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD56FH96 56" Television Logo
1,200 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
