My 500W powered aspire alienware case
I am having problems getting my panel leds wired up. My ECS MB doesn't list the configuration from my case and the plugs differ--the old 3 wire power led plug is now a 2 wire with the leads spread apart--not together.
    Novelist:
    Champion:
  • 231 Answers
Hi, this can be a common problem, get a small set of side cutters and gently split the plugs to seperate each one. then plug the 2 you need on to the board, turn them sideways so they do not interfere with each other. when pluged on the board you may need to swap them around till they work. Dont worry if you get them the wrong way around you will not do any harm. note there are no adaptors for these connections. Regards mistyman
Posted on Sep 09, 2007
Motherboard confuchion
http://www.asus.com/Motherboards/M2N68/HelpDesk_Manual/
Nov 22, 2013 | ECS Computers & Internet
WIRING CONNECTION
You'll need to download the manual for you're ECS P4VMM2, MB.
If you no longer have it.
Left click on the link provided by ECS below to open;
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=P4VMM2
There are many version for the P4VMM2 MB. Look closely on you're MB for the correct revision. There are slight differences between each revision. You will also need to download Adobe reader to view the manual. If you do not have Adobe reader installed click on the link to download and install Adobe. (Adobe is free).
http://www.adobe.com/products/reader/
The most important connections start on page 11 to page 14. For front panel wire connections. Hard disk drive LED, Power LED, Reset LED ECT, keep in mind which wire color is ground & which wire color is positive. You'll find 1 common color for each jumper. This common colored wire will be used for ground. The other colored wires will be used as positive. (Execpt internal speaker). Internal speakers normally use the color red for positive and black for negative.
Just follow the manual and you'll find it is not very tough.
If you get confused or lost feel free to post questions.
Cheers'
Mike
Aug 20, 2010 | EliteGroup P4VMM2 Motherboard
Wiring diagram on a elitegroup k7sem
There are a few ECS motherboards listed on ECS web site. Each has a different revision number. Choose your correct version and download the manual for the MB. You will also need Adobe reader installed to view the manual. Adobe is a free download; http://www.adobe.com/products/reader/
ECS K7SEM MB;
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=K7SEM
Once the manual is downloaded go to page 10. Turn to pages 16 & 17 to connect your case to the MB.
Cheers'
Mike
Aug 10, 2010 | EliteGroup K7SEM Motherboard
Where does the HDD Led, Power SW, Reset SW, and Power LED plugs go on the ECS GeForce6100SM-M motherboard
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
May 12, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Instructions on atx case wiring to motherboard
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
4 FP PWR/SLP *MSG LED (-)
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Jan 28, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
ECS 755 A2 motherboard problems
Make sure you have the correct front panel header connected correctly to the case wires. Open you're manual to page 12 under the English section. There you'll find a picture of the front panel header & how to connect the case's LED's to the motherboard.
If you no longer have the manual you can download it from ECS at this link.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=381&DetailName=Manual&MenuID=1&LanID=0
Chances are you may have the wire's connect backwards. (Positive + connected to the negative - ECT).
Example, pin 1 is the + for hard disk drive & pin 3 is - for the hard disk drive. Cases vary on wire colors, normally if each connector has a common colored wire (solid color) that common wire would be the negative. Stripped wires are negative. Other cases use white colored wires as negative & colored wires as positive. As far as you not receiving any display. Try removing the AGP card & clean the copper contacts. Clean with alcohol.
Place a couple drops onto a cotton swab & clean the copper, both sides. Blow out the AGP slot with canned air. Re-check all connections, power & data cables before closing the case. Power on the system & check the front led's for operation.
If you still fail to get display, re-check the connection from the monitor to the case. Try you're monitor on another system. If good than you're video card could be bad. You're motherboard can run an 8x/4x speed AGP 1.5volt (only) graphics card.
Good luck zeratu_l !
Need more help? Post within this link.
Mike
Jul 28, 2008 | Computers & Internet
Wiring a P4M80-M4 mother board
You can download the manual for the motherboard here, just click on the "manual" link:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
This will list the front panel connections, which are 2 pins. Each of the jumpers, what you are calling clips, will connect two of the pins. Most cases have the jumpers labeled, i.e. power, reset, etc. But if they are not, it is usually: red/white = HDD led; green/white = power led; red/black = speaker; black/green = power switch; and black/white = reset. But your case may use a different wiring spec, but should list somewhere which wire is for which function.
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
298 people viewed this question
Alun Cox
David Payne
David Payne
