Samsung UN50EH5300 50 LED HDTV Logo
A
Anonymous Posted on Aug 24, 2013
Restore un50eh5300 tv - Samsung UN50EH5300 50 LED HDTV
Samsung un50eh5300 dead set,no stby led,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My Samsung smart TV has sound but no picture. It lights up but won't show picture. It's a UN50EH5300
Check the backlight if you have backlight only two things will solve the issue . The Tcon board board need to be changed. The other would be to get another main board those tow parts I mentioned will solve your issue would try the tcon board first
2answers
I have a 50 inch Samsung Smart TV UN50EH5300 that went dead...so I replaced the voltage supply board and it came on sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I fix my 50"Samsung led t.v?
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Movie picture does not fill screen
If it's an older movie it will not fill the screen . It was never meant to play on a wide screen TV so the only thing you can do is use the zoom and stretch features on your remote. You may not like the results.
What caused video failure?
Why is there sound but no picture?
Sound goes to 100% by its self
The pcb with the volume + & - and ch + & - is faulty. The easiest and cheapest way to repair this is to take the back off your TV and just disconnect the plug and socket on this pcb. The remote will work the TV as usual. Hope this helps
Sound level raises to 100% on its own after about 5min when turned on
Touch pads on front of set have gone faulty (eg.vol up and down + pr+ & pr-) common fault with samsung tv's.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
