Question about OEM Systems PIXMA iP3300 Photo Printer
Printer fail to recognize the ink cartridge
My NEW Pixma ip3300 won't recognize my PGI-5 black ink cartridge. It was working well for some time and all of sudden (I just refill it) the cartridge isn't recognized. When I take it out and reinstall it the cartridge lamp goes on, but when the printer resets itself the indicator lamp goes out. I have also turned the printer on and off and even press the RESET button for 5 seconds...nothing works. Any advice would be appreciated to get it fixed.
  • 1 more comment
  • Anonymous Jan 01, 2008
    YELLOW CARTRIDGE IS NEW AND FULL AND CAME WITH PRINTER, SUDDENLY, THE LIGHT GOES OFF, AND THE PRINTER SAYS HAVE TO BE REPLACE...WHAY KIND OF JOKE IN THIS ???
  • syifar Apr 04, 2008
    my black ink is not recognize this is my poblem in cann pixma ip3300, do some one to help me?
  • renepants Feb 05, 2009
    Mine (pixma ip4300) refuses to recognise the magenta cartridge.
    I've tried new cartridges, cleaning the contacts on the cartridge and the contacts in the printer.
    Resetting the machine has worked in the past, but now I've done more than 50 resets, and still it won't accept any magenta cartridge I put in it.
  • OEM Systems Master
  • 1,830 Answers
You need to wait longer for the printer to recognize the ink cartridge, but first clear all cartridge error messages on the printer.
Posted on Jun 25, 2017
3 Suggested Answers
SOURCE:
  • 390 Answers
SOURCE: Canon PIXMA iP3300 Won't Work!
My first suggection is to return it to the store for a full replacement with you original receipt. No way should a printer do this just out of its box. The more you fiddle with it, the less likely to be able to replace it (and the longer you leave it to. If you leave it too long, you will have to have it repaired under warranty. You can try uninstalling it by following correct pc directions at remove programs menu. Then, unplug it after turing it off. Replug it, reinstall it. Try printing now. If still no good, repeat the whole process but this time, do not reinstall with original disc. Make a copy and reinstall the printer with the copy. Noe try printing again. If no luck, return it to store in as original condition as you can manage with all softwares and mauals and your receipt and demand a replacement, Under fair trading they cannot refuse.
Posted on Sep 01, 2007
SOURCE: Printer won't recognize ink cartridge
Guest again:
Called Canon.   It is a defective cartridge and they are going to send me a new one once I fax in my receipt for the purchase of the printer.
Posted on Oct 24, 2007
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have a mp530, and when the large black is out of ink, it wont print. It has a second black cartridge, but it seems as if that is never used and not needed. What is wrong? Why have 2 black cartridges if...
Printer use big PGI-5 black cartridge have pigment ink for printing text, documents or other only black pages.The little CLI-8 cartridge have dye-based ink for printing photos and other color pages.You need to replace your PGI-5 black cartridges to continue printing.
Nov 16, 2009 | Canon PIXMA® MP530 All-In-One Printer
I have a Canon MX850, I don't understand why my big black ink cartridge is full and it uses only the small one, how can I change to use the big one?
The printer use big PGI-5bk cartridge to print documents and text.When you print photos or some other pictures printer use small CLI-8bk cartridge because this cartridge has a photo ink.If you print text and it print blank page that mean the nozzle on PGI-5 cartridge is clogged.Try cleaning test on maintenance menu on printer.
Oct 29, 2009 | Canon PIXMA MX850 Multifunction Printer
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MX850 willnotprint from Large Black Ink Cartridge - PGI-5BK
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like
https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
Feb 15, 2018 | Canon PIXMA MX850 Multifunction Printer
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Need to change cartridge on ip3300
Greetings...
This Canon ip3300 has four ink tanks... PGI-5 Black, CLI-8 Cyan, CLI-8 Magenta, CLI-8 Yellow
Lift the front of the printer while the printer is on and the ink tanks will move to the center... the empty tank will have a blinking red light... the inks that are ok will have a steady red light... press the small tab in front of the ink tank that is blinking and remove... insert and press down the new tank and make sure the red light is on to show you have replace the ink correctly...
This should work, let me know if you have any additional questions...
Ed
Apr 08, 2008 | Office Equipment & Supplies
How to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Dec 13, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Error:u043
1st step: Press and hold the Stop/reset button for 5-10 sec then release. I
f ot working then use a Qtip and moisture (not wet) it with water. Cleans the chip gently and re-insert it back and redo the 1st step.
It work for me everytime!
Nov 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
I had the same problem with the yellow cartridge.   At first when I resinserted it, it would solve the problem, but today even that didn't work.
I did solve the problem by clearing all print jobs, turning the printer off and then on, and then running a cleaning cycle on the color nozzles.   I don't know why this fixed things, but my yellow was suddenly recognized without any further fiddling.
Sep 07, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Open Questions:
See all OEM Systems PIXMA iP3300 Photo Printer Questions
OEM Systems PIXMA iP3300 Photo Printer Logo
193 people viewed this question
Top OEM Systems Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Inky Fingers
Inky Fingers
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
