Refer to your service manual, or I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: need to peplace fuel line in gas tank.whats the easy way to do i
Watch the video, bar far the best method I have found.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
• The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
• If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
• The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
SOURCE: My McCulloch chain saw fuel line has evidently
Yes you can do a generic one, just get to any chain saw rea pair shop and tell them your problem or go to Mcculloch.
SOURCE: How do you hook-up new fuel lines on MacCat 2.3
OK, there are two conections on the back of the primer, the longer conection is the pressure side, so this has a hose back to the fuel tank, it will just push into the tank with nothing on the end, the shorter connection on the primer is the suction side, this pipe will go to the carb, the conection nearest to the metering cover of the carb, usually a chrome cover held with four screws, the other connection on the carb, nearest to the pump cover, usually alluminium held with a single screw, goes to the fuel tank with the fuel filter on the end, just remember the primer pulls fuel from the carb, into the bulb and back into the tank.
Testimonial: "Explained well. Thank You"
SOURCE: new chain for 16'' 35 cc mcculloch
PartsBuggy.com has all the bars and chains you need for your saw listed here.
