Akai LCT3201AD 32 in. LCD Television
Problem for Akai LCT3201AD 32 in. LCD Television
My tv Wont Turn On
By mayo_jack626 on Sep 08, 2007
I Have A Akai LCT3201AD 32 in. LCD and after watching it for about an hour last night, i turned it off. when i went back in a couple hours later, the tv wont turn on. the side power button doesnt not work. the Remote Control does not work. i Tried a different outlet and that does not work. The only response i have is a faint blinking red light on the infared area.
Same Problem
Apr 08, 2009
-   My TV would not turn on. The red power indicator light is flashing and never turns green. I tried to power it using power switch and remote control. Nothing works. I sent email to Akai support. Let's see if I get any reply. This is my last Akai product purchased - that's for sure :(-   silvntania
Mar 05, 2009
-   I turned on the TV with the remote and after a few seconds it went off.  I have been unable to get it working again after unplugging to reset a dozen times.   The red standby light will react to the start instruction but then goes red again.   The TV is about 3 years old.-   DavidwnoTV
Mar 01, 2009
-   it started not comming on on the first try then 2 trys then 10, 20 200, now i play a game with unplugging it andd plugging in while pressing the power button. definate factory defect in the design.-   willieb12
Jan 08, 2009
-   I tried to turn my tv on and the red light just blinks. I unplug the unit and wait a few seconds. plug it in and then it comes on. -   Guest
Jan 04, 2009
-   Same problem, try to turn it on & it shuts down. I tricked it by unpluging & then pluging it back in, then using the remote, worked for a short time -   Guest
Best Solution
posted on Jun 23, 2008
Very Helpful)
calp
Rank: Apprentice
Rating: 100%, 4 votes
My 32" hyundai LCD TV will not turn on. The power lead is ok the on / off switch on the side turns the red stand by light on and off. I am unable to get the LCD TV off stand by. I have tried the the stand by button and this does not do anything. Can anybody help.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 09, 2007
Helpful)
LCDMAN2000
Rank: Apprentice
Rating: 92%, 5 votes
I have been trying to get a service manual for the same unit with no luck. I have the same issue, I finally ordered me a power supply from Megmeet who makes then for Akai, and back to normal.
Was this helpful?
Yes
No
Solution #3
posted on Jun 03, 2008
Helpful)
crowbird
Rank: Apprentice
Rating: 60%, 3 votes
i have the same problem i try everything.
Was this helpful?
Yes
No
Solution #4
posted on Nov 01, 2007
Somewhat Helpful)
TitoA
Rank: Apprentice
Rating: 84%, 12 votes
My TV went out also. Power supply was the issue. I replaced the thermistor NCT-5-D13 and that fixed the problem.
Was this helpful?
Yes
No
Solution #5
posted on Sep 08, 2007
Somewhat Helpful)
Shuttle83
Rank: Guru
Rating: 85%, 991 votes
You may have a power supply issue. What you need to do is to get the schematic for you TV. You can do this by calling the manufacture and asking for the service manual and the engineering diagrams for the TV. They will charge you but that is part of the cost of fixing these sets. After you have the schematic get a multimeter (you will need it to take voltage measurements. Or you can just get the scematic and ask one of the shops on FixYa to troubleshoot the problem and fix it for you. In any event this problem should be handled by a qualified technician.
Was this helpful?
Yes
No
Solution #6
posted on May 03, 2009
Very Helpful)
rkrgecotn
Rank: Apprentice
Rating: 100%, 2 votes
I have a AKAI, mod.LCT3201AD, that would not come on ,side buttons or by the remote. The green lite would flash on then off.
I had repaired a Poloroid flat screen for my daughter, and the same problem and the same repair fixed the no turn on problem.
Now thru experence of 2 simular power supply units in the rear of the screen, I have found that in 2 cases that filter caps of 16 volt rating have swelled uo on top end and checked open or low capacitence and/or shorted. They appear to be under rated, voltage wise for the power supply.
On the Poloroid flat screen and the AKAI flat screen, repacing the 16 volt rated caps with 35 volt rated caps fixed both flat screen sets. The Poloroid set was repaired 6 months ago and still running.The AKAI was repaired yesterday and has normal pic and sound and remote operation.
Maybe this will help someone on this cheep made Chinese junk.
Thanks, RKRGRCOTN>
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #7
posted on May 01, 2009
Very Helpful)
Ed the tec
Rank: Apprentice
I just got one of these in my shop and just replaced the (3) 16volt 1000uf caps in the power supply.
Tv works fine now.
Ed
Was this helpful?
Yes
No
Popular Solutions for Akai LCT3201AD 32 in. LCD
Questions and Unsolved Problems for Akai LCT3201AD 32 in. LCD
Do you recommend Akai LCT3201AD 32 in. LCD Television?
Answer
Answer
I have a 32" AKAI w/DVD. As I was watching TV the screen went black. The sound is fine. When I... (More)
Answer
need a universal remote that will work w/ akai 32 " tv/dvd tried phillips & rca
Answer
power wont come on . Red light turns green then back to red.
Answer
The sounds isnt working right. on stereo sound sometimes it doesnt come through and it sounds really... (More)
21 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 31, 2008
At first I could not turn the tv back on with the remote unless I punched to power button on it several times. Then after a few weeks, it got worse and when I did manage to get the tv running, it would shut down after about two or three hours and I had to wait for an hour or so before I could get it back on. I tried a new outlet, new electrical strip and replaced batteries in the romote. All to no avail. Anyone got any service manuals or suggestions? Anything would be helpful. HLHerm18@att.net
Comment by ARTIST2STARS, posted on Dec 29, 2008
I HAVE THE SAME PROBLEM, THE TV WORKED FOR ABOUT 2 MONTHS THEN IT WOULD NOT TURN BACK ON, I GET A LITTLE RED FLASHING LIGHT AND A CLICKING SOUND, AND NOTHING ELSE. I CALLED THE COMPANY AND THEY TOLD ME THEY WOULD CALL ME BACK. 64 TIMES.. STILL NO PHONE CALL BACK.. HORRIBLE COMPANY, NOW MY WARRANTY HAS RUN OUT AND I AM STUCK WITH A BIG PIECE OF JUNK... AKAI SUCKS,, AND I AM GOING TO POST THIS ON EVERY WEBSITE I CAN.. EVERYONE IS HAVING THE SAME PROBLEM.. GEE YOU THINK SOMETHING MIGHT BE WRONG WITH THE MANUFACTURING OF THESE SETS. IF EVERYONE CAN GIVE ME THEIR EMAIL ADDRESS, I WILL START TO MAKE A LETTER OF COMPLAINT TO THE CO. AND TO WALMART/ SAMS CLUB AND THE BETTER BUSINESS BURAU ... IT IS NOT FAIR TO BUY A TV AND DUE TO DEFECTS I SHOULD HAVE TO PAY TO SHIP IT TO THEM OR FOR SOMEONE TO FIX IT AFTER ONLY 2 MONTHS OF USE.. TOTAL RIP OFF.. MY EMAIL IS.. ARTIST2STARS@YAHOO.COM. MY NAME IS PATRICIA .
Comment by cabralesvero, posted on Aug 05, 2008
i lost power because of a storm and now my tv wont turn back on. there is only a red light thats makes a little noise when i press the power button
Comment by Guest, posted on Aug 02, 2008
Cannot get picture, sound is there.
Comment by louiswatson, posted on Jul 25, 2008
i have owned this model for more than a year, this last month when i turn the tv off it would take atleast ten tries for it to turn, now i just unplug and plug in before i try to turn it on and that been working, but i want it to work wright!.
Comment by Guest, posted on Jul 06, 2008
my akai lcd 32 in won't power on we tried every thing we could we changed cable boxes we changed locations for plugs. We are extremely frustrated please help ETLyons@Peoplepc.com
Comment by pattiinvegas, posted on Jul 06, 2008
This tv was not even a year old and it will not power up.
Since I purchased the extended warranty we had techs out twice.
Neither one could fix it. So I got my money back, part of it.
Could it possibly be the power supply or the starter switch?
Pat
Comment by Guest, posted on Jul 01, 2008
My problem started a month ago but at first the TV just wouldn't turn back on with the remote. i could turn the power button on the back of the TV off and then on and then the remote would work but eventually it started taking multiple tries to of turning the back power button off and on then using the remote. I finally got tired of that and just stopped turning the TV off and instead would only turn the cable box off. Just got back from vacation and the house-sitter turned the TV off via the power button on back of panel and now it won't come on at all. This is ********. Someone needs to know how to fix this.
Comment by Broncofan1, posted on Jan 10, 2008
LCDMAN2000, Do you by chance know the part # or something to order from megmeet?
Comment by Guest, posted on Dec 31, 2007
 All of these flat panels TVs with power problems should be sold to customers at there own risk. due to my understanding through akai's web site there is no fix. That is also no fault of ours. thanks akai for thinking of your customer first. Now they're are customers who are not in a rush to spend there money with Akai again.  Let's say $.700.00 x 10000 customers= 7 mllions unsatisfied customers. Somebody not getting ah bonus huh!
Comment by bigroy42, posted on Dec 16, 2007
turn tv off for about an hour tried to turn it back on would not come on ,an the redlight just keeps blinking . i changed sockets that did not work either,so i checked the batteries in the remote to see if that would help it did not.
Comment by 1mrnavy, posted on Dec 09, 2007
I have the same problem, I did what the manual said to do. At one time if I tried too turn it on using the standby, it would come on after a few trys.
The remote wont work at al. yahnks for your help
Mike
shipmate67@hotmail.com
Comment by Kenowski, posted on Nov 26, 2007
I have the same problem, worked fine eralier this morning and went I turned it back on around lunch time It appeared to have no power.
Could not get it going on the side panel or by using the remote. The outlet were the TV is plugged in works fine. I call the 1800 number for technical support but there was nothing they could do, gave me the number of a contact person in the area.
Comment by Guest, posted on Nov 04, 2007
I have a Philips Magnavox that will not work. I changed the batteries; I still get the red light appearing when I press buttons on the remote control. What shall I do? I would appreciate your suggestions to resolve this problem.
Thank you, coach14232004@yahoo.com
Debbie
My tv won't turn on until you repeadtedly press the on button. At fist it took two or thee time of pushing the on button, but now it takes five to ten minutes to get the green light to stay on turning on the tv.
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
