I have a candy cdw 254 dishwasher and plastic that holds bottom drawer, broke so the drawer falls...
(More)
I have a candy cdw 254 dishwasher and plastic that holds bottom drawer, broke so the drawer falls down and machine can t wash it as it should. I tried to remove the plastic part so i can change it, but the thing that holds it(screw) is not a ordinary screw it doesn t have cross hole neither ordinary hole so the screwdriver is usless as well as wrench and L wrench!? BTW sorry for my bad english.
very little water fills the dishwasher. the arm of upper rack does not swivel. water does not come...
(More)
very little water fills the dishwasher. the arm of upper rack does not swivel. water does not come up to the arm of upper rack so dishes aren 't washed at all.
i looked underneath,and the water was leaking from what looks like a water inlet valve or switch,it...
(More)
i looked underneath,and the water was leaking from what looks like a water inlet valve or switch,it is black plastic with 2 wires joined to it,then on the other side it joins a short rubber hose which is connected to a motor/pump which does not turn when switched on,this pump has 3 wires connected to it leaving 1 unused terminal on the pump,maybe this is correct config.,as i found no loose wire spade connectors, can you help,thanks;;,,wesha.
