Question about Mitsubishi WS-65819 TV
Bow like image
The Mitsubishi WS-65819 has worked great until the last month. Now the picture will periodically bow in the middle (Image from top left/right and bottom left/right will bow towards the middle of the screen) of the screen and distorts the picture usually while watching a show. This occurs for both DirectTV and DVD movies and is increasing in frequency. Any suggestions on what is causing this? Is this something that i can repair myself even if i am a novice? Any help will be much appreciated. Thanks!
  • 87 Answers
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 22, 2007
SOURCE:
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
Blue shadow
Good Day,jmurf1037;
Yes, you have a convergence problem.From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
Aug 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture Bowed towards the center
It is a convergence problem, probably one of the convergence ICs has blown and must be replaced. Call the number in the last pages of your user manual to get repair service in your area.
Jul 25, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Intermittent convergence issue became permanent
Hi Ed,
Your convergence amplifiers are definitely bad. The user manual will not work, since it is the same manual that comes with the set when it was new. The service manual can be found at:
http://servicemanuals.net/results.aspx?type=SM&brand=0&model=WS-65819
Best Regards,
MyTvGuy
P.S. Thanks in advance for rating me!
Feb 09, 2008 | Mitsubishi WS-65819 TV
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
