Question about Flat Panel Televisions
Tuning plus "smartlink" message
I stupidly selected auto tune and lost one of my channels...but now I keep getting a message flashing up on bottom right of the screen saying, smartlink sending: programme 1 etc.....I can't get rid of the damn!!!!
2 Suggested Answers
  • 227 Answers
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Posted on Mar 23, 2009
  • 11800 Answers
SOURCE: I bought an LG 32LD460.
The tuner inside the tv has failed - which is quite odd since you just bought it. Take it back and recover your money, you got a lemon.
Posted on Aug 09, 2010
0 characters
1 Points
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
Jun 29, 2014 | Flat Panel Televisions
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
Sep 07, 2011 | Flat Panel Televisions
How do i tune the channels on a toshiba rc3910
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
Jul 10, 2011 | Toshiba Flat Panel Televisions
In all models the tuning can be done manually and in auto mode from the Remote control unit.
Open the menu and open tuning to scan and memorise the channels.
If you have to select manually try the manual mode and arrange according to your choice or you can move the channels from the auto mode .
Jun 13, 2011 | Flat Panel Televisions
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
How to get and store all the channels automatically?
u can auto tune ur tv for storing channels aromatically through the following steps
1. press MENU button and then select CHANNEL and press ENTER.
2. select country and press ENTER AUTO TUNE and press enter.
4. press ENTER again.
wait till it memories all available channels.
after auto tuning it will display sort channels. if u want to sort channel, do it, if not exit the option.
Dec 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Hi I have just retuned my tv but have found that the identity number(ie BBC1 is D.001, ITV is D.003) for channel 5 is D.800 which Guide plus uses but the TV recognises channel 5 as 005! therefore I cannot...
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit
For specific model information visit
Oct 03, 2009 | Sony KDL-26S2010 26 in. LCD Television
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Flat Panel Televisions
Tuning 5 uk channels
It depends what make of TV you have, basically you need to auto tune it to get the stations back. You need to select your MENU, then TUNING, then AUTO TUNE wait until it tells you completed, then STORE.
This should Fixya!
Please remember to rate this solution .
Oct 23, 2008 | Flat Panel Televisions
Flat Panel Televisions Logo
174 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
