Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
The upper spray arm has dropped off
This must be an easy fix, but I can't find a thing about it in my manual or online. The upper spray arm has spontaneously dropped off its mount, and I can't find any screws, etc. in the bottom of the washer, so I'm wondering how to get it back on? Do I have to replace the whole part?
  • Hebes Apr 13, 2009
    I have the same problem, the upper spray arm as fallen off. There seems to be nothing to attach it to on the roof of the inside of the washer? There is not broken part in the bottom of the tub either. And the parts listings for this washer don't show any part or any illustrations to show how the arm re-attaches?
  • 209 Answers
I am a recently retired appliance engineer of 20 years normally these arms just clip on, if it is worn or broke then the answer is yes replace the arm, there are no screws as the part has to spin very freely, look for wear or any small bits of plastic in the filter hope i have helped you as to what to look for, if so rate me please
Posted on Sep 09, 2007
SOURCE:
KitchenAid Custom 21 Dishwasher. The arm for the upper rack does not rotate or spray when in use. Water just dribbles out, so dishes in upper rack do not get clean.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 22, 2011 | KitchenAid Dishwashers
I recently found the upper spray arm in the bottom of the dishwasher after running it. I can't see any piece broken off of it but I also can't see any way to put it back on. I suspect some small piece...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Jan 05, 2011 | Frigidaire FGHD2433K 24 in Builtin...
My LG dishwasher upper rack has stopped cleaning. The uppermost arm is seemingly getting no water at all and the arm on the underside of the upper rack is getting some water, but not enough to turn it. I...
Dishwasher
How to Buy
heatman101
Dec 24, 2010 | LG LDF6810 Built-in Dishwasher
There is no water coming out of the upper arms. The upper arm assembly is clean. is there a filter somewhere I can clean to increase the water pressure?
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Can someone please help. No water is coming out of lower and upper spray arm. Spray arms are clean.
heatman101
Sep 26, 2010 | Bosch 24 in. SMU20 Built-in Dishwasher
Water is not spraying through the dishwater. The upper arm doesn't appear to have any water going through it as the upper dishes are dirty. Maybe not the bottom arm either as the soap is still in the...
heatman101
Sep 26, 2010 | Maytag MDB7100AWB Dishwasher
My Kenmore 665 leaves food residue on glasses on the upper rack. What can I do to fix?
heatman101
Sep 25, 2010 | Kenmore Dishwashers
Upper rack spray is clogged
it has a pressure insertion fitting that snaps into the arm thru the hole,you need to press in on the ears on the bottom of the are to release the plastic grips to let it drop out,then the arm should remove after this
Apr 19, 2010 | Maytag MDB5100A Dishwasher
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Upper Spray arms not spraying
Took apart again and found the stepping motor which diverts the water from lower to upper spray arms to be burnt out. I was able to manually set the diverter to the correct position so the dishwasher works but I am waiting for new parts to properly repair the problem.
Oct 09, 2009 | LG LDF6810ST Stainless Steel Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
139 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
