Question about RCA RT2760 System
RCA RT2760 with iPod
My ipod says "do not disconnect" and the rt2760 says F0 T0 - but I have more than 0 songs and playlists! Please help! Thanks! (sorry for posting this as a solution before)
5 Suggested Answers
  • 108 Answers
SOURCE: RCA RT2760 Home Theatre
1. Problem with Power supply unit
2. Problem with power amplifier unit.
Contact service centre
Posted on Dec 22, 2007
  • 3587 Answers
SOURCE: RCA RT2760 problem
sounds like you may have blown the internal amplifier a handy sort of person?
Posted on Apr 20, 2008
  • 4 Answers
SOURCE: RCA RT2760 has no sound
power no sound
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
  • 2098 Answers
SOURCE: Subwoofer stopped working on my
First check if the speaker is not faulty. Using your ohmmeter(set in resistance measurement) test the continuity of the speaker. If not available, spare battery (D,AA,AAA) may used to confirm the sound from the speakers(test the two wire of the speaker through both end of the battery). Upon testing the continuity of the speaker you will hear a slight crackling sound .
No sound - your speaker voice coil is already open(blown). You must replaced it with new one or rewind the voice coil to the shop specialized in speaker rewinding.
Yes it has sound - Then the fault was came from the amplifier/receiver. I'm assuming that the settings is correct and the speaker is properly hooked up, the sub-woofer sound output IC(mounted in heat sink) is going to be check for faulty. Most of the case it was already blown(shorted or open). You must check it using the ohmmeter.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for an experienced technician to isolate the problem.
Also, check if your unit is still under warranty perio(1 year from the date of purchased), avail it because the manufaceturer will fix it for free. Don't attempt to open the cover of the unit, it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 17, 2011
0 characters
1 Points
RCA RT2760 problem
Apr 20, 2008 | RCA RT2760 System
Someone cut the power cord on my subwoofer RCA model rt2760 can i replace it with a standard plug?
if its a standard 120/ 240 volt cord with three cores live /nuetral/ earth yes
Aug 02, 2011 | RCA RT2760 System
RCA RT2870 USB won't allow playlists or let me skip folders
I have this same system and it looks like the USB playback is lacking this feature, of switching folders. A workaround is to use shuffle play to jump to one of the last songs in the first folder, then turn off shuffle and skip forward a few songs until you get into the next folder....and so on. Not very good, but for this price I was glad to have USB playback.
Some generic MP3 players will work in the USB port, but they play exactly the same as a USB drive. SO no real solution for this.
Jan 16, 2009 | RCA RT2760 System
System doesnt read usb
It can't read an iPod through the usb port, it can only read standard flash drives I think. Using the "Line in" would work better.
Mar 30, 2008 | RCA RT2760 System
RCA RT2760 System Logo
Top RCA Home Theater Systems Experts
Are you a RCA Home Theater System Expert? Answer questions, earn points and help others
