Question about Kodak EasyShare C643 Digital Camera
Canon power shot sd450 camera not working
My camera is not working. When I turn it on I can't see to take a picture. I see E18 flashing.
  • Anonymous Apr 09, 2008
    I am having the same problem! did you ever fix it?
  • Anonymous Jul 06, 2008
    my **** gets hard but my camer wont turn on
Just pushit in your ass... and tur it on... it will work perfectly
Posted on Dec 26, 2007
SOURCE:
Canon sd450, e18, need schematic of lens
http://www.e18error.com/
here are instyructions and a reference to the schematic at the bottom of the page.
cheers
Jul 31, 2009 | Cameras
Our Power Shot SD450 digital elph,5.0 Seems like the shutter stays open to long. Pictures come out too bright
is it showing any error message? like E18 or any other error?
did you try a hard reset?
Oct 21, 2008 | Canon Cameras
Self shooting for canon power shot SD450
You mean SELF TIMER?
Big dial on the back>press it down until you can see "Clock" sign on LCD>press release button
Mar 25, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 10, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
I cannot figure out how to turn off the flash on my canon sd450
You first need to change the operating mode to Manual. Then you can change the flash by pressing the right button a few times.
Nov 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Display Canon sd450
The backlight display of your camera is now defected cause of high vibration when you felt out and bangs into the ground. I don't see if this replaceble but you still has an option contacting the canon.
Thanks
Feb 28, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
E 18 problem
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Jan 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Kodak EasyShare C643 Digital Camera Logo
37 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
