Hello, i have a insignia lcd tv. the model number is NS-20LCD. i was watching the tv and i turned up the volumed and the tv locked on me. i don't have the original remote i do have a sony universal remote. i have turn it off and let it sit unplug for a day or so and it still turns on lock. Any advice or solutions would be nice. thank you
hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
Turn on tv
Press and hold the menu button (you will hold this through the next few steps till the menu comes up)
turn the tv off using the silver button on the back of the tv
push the button back in on the back of the tv
tv should come on and bring up the menu
using the channel and volume get to the menu with the v-chip controls there should be a reset menu button change it to on.
turn off tv using power button on front of tv.
turn it back on and problem should be solved
Comments:
Dec 04, 2007
- hi guys got same tv same prob......finally after hours of frustration found a solution.
steps:
Turn on tv
Dec 04, 2007
- any questions e-mail me at jon_8221986@yahoo.com try to help ya as much as i can cause i know how frustrating it is
Was this helpful?
Yes
No
Solution #2
posted on Dec 12, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
What remote is it?
Solution #3
posted on Jan 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had the same problem, but i had a Philips PM435S Univeral remote, I just started guessing different combinations, and found that pushing the code search button and then pressing 0 unlocked the tv
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light...
(More)
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
I am having an issue with my Sony KDE-42XBR950 or the set top box which you must use to attach to...
(More)
I am having an issue with my Sony KDE-42XBR950 or the set top box which you must use to attach to the TV which is MBD-XBR950. I believe the box is what controls the power supply but I don't know if it is the box or the board in the plasma causing this problem. The TV turns off and on at will. I cannot even make it through a half hour program without power failure. But when it turns off it can be turned back on manually at the box, but only if you stand there and hold the button. But it also turns itself on when there is nothing around it as well. I have removed all remote batteries from every tv in the house as well as unplugged every electronic device with a remote but nothing has changed this issue. By the way it also just started doing this out of the blue. Any help is greatly appreciated. Thank you in advance.
the picture is flickering to black rapidly. it's not all the time and usually lasts about 5-10min...
(More)
the picture is flickering to black rapidly. it's not all the time and usually lasts about 5-10min and then slowly gets better but it seems to be lasting longer recently. Thanks for any help. Dan
