Lightware vp800 we turn on projector, fan works, light comes on, fan is on high working properly, it runs for 6 minutes, then only the light goes off and the fan stays on (in high position) and within 1-2 minutes the light comes back on and runs for another 5-6 minutes and the light goes off again. Can the thermal switch be bad? We think unit is cooling properly. When turned on and then off fan runs in low position, working properly also.
  • annac213 Jan 16, 2009
    same here. cleaned the fins? filter things? inside, and its still doing the same thing.
  • Anonymous May 20, 2009
    very similar problem. Lamp 600 hours use. Turns itself off oafter 5-6 minutes with red lamp warning. Plenty of life in lamp. Filters cleaned, fans cleaned, lamp tightened, slight hot/burning smell when turned on but cannot see anything overheating - probably just the lamp?
    Turning off and on seems to reset
    Could it be a thermal cutout?
    If so does anybody know where this is located before I go delving?
I Have a lightware vp800 plus. I pushed the mute button on remote control and Now I cant get sound at ALL. Do you think the sound card went on it? Checked the menu etc. and nothing. Help I have NO SOUND :)
Posted on Jul 15, 2011
  • 2,237 Answers
Blow out the dust, check the fans, and then replace the thermo sensor if necessary
Posted on Dec 22, 2009
After my vp800 plays for a hours it cuts off. WHY?
Remove the cover and check whether the air filters blocked with dust.
Whenair filters are blocked, air doesn't flow freely through the projector. This result in overheating, leading to automatic shutdown.
Sep 21, 2011 | Lightware VP 800 Plus Multimedia Projector
Light goes on and off lightware vp800
Hi, How long have you had the unit? If its new take it back and get warranty repair. If longer then, try giving it a good clean. Get some "Air Cans" if you can to blow trough the vents. It could be dust/dirt on the sensor. If you clean it first then we can be sure. If you are ok about taking the casing off then you can give it a better clean. If after cleaning it is still playing up, it is an overheating problem and best repaired by proper service centre as they can get the parts you need.
Sep 08, 2007 | Audio Players & Recorders
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
When I connect a Lenovo w500 laptop - using windows xp - the screen of the laptop becomes magnified and the the image from the projecttor reflets same magnifacation - when I disconnect from projector and...
You don't probably, your laptop screen is not exactly becoming magnified, the resolution is being lowered to match the maximum resolution of your projector which is only 800x600. They are setup as "cloned" together. You could try setting up an "extended desktop" rather than having the projector "cloned" with your laptop screen, that way you can change the resolution (within their allowed limits) of both displays independently. To do this, Right click on desktop and select video setting or the control panel of whatever video card you have. If you can set up an extended desktop, it is here that you'll be able to do it.
Jan 10, 2010 | Lightware VP 800 Plus Multimedia Projector
My Lightware VP 800 fan turns on but when I press the power on button it powers up but no light comes on. The bulb does not need to be replaces. any ideas?
Check the bulb with a multimeter or it could be the ballast .Lots of times it an easy solution like trying another ac cord that fits better or even the ac fuse.
Mar 02, 2009 | Lightware VP 800 Plus Multimedia Projector
Manual for lightware vp800, and i can't get the sound to work
Try changing to your S video wire input.If you hear a cracking sound it could be you've blown your speakers.It depends on your application but I run all my DVD equipment through my stereo system,just run the same video wire to your stereo and select that input on the stereo .And yes they do have remote controls,try ebay where you can get another vp800 w/remote under 100.
Dec 22, 2008 | Lightware VP 800 Plus Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
If the power comes on the power box, that is good, so the only the is the mother board is bad, replace it. they have nubers on the that tell you what kind it is. search the web, you can find the new on ebay check, and you can put it in your self and save time and money.
Sep 02, 2007 | Computers & Internet
VP100 Projector Powers Up But Doesn't Light Up
Well, If you are pushing the power button beside the lens and the fans speed up but no light is on hte lights might of gone out as of now i have the same projector no one has a replacement bulb but if the fans just go steady and does not speed up when you power it on the there night be a problem with the button try the remote if you have it otherwise it just might be the bulb,
Hope This Helps
Jan 20, 2007 | Lightware VP 100 projector lamp Projector...
2,275 people viewed this question
