Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi tv 52'
Tv was turned off night before. turned back on. blue screen only,showing antena-A.click input goes to antena B it doesn't go to audio or vodeo so you acn't see the chanels.if you go to menu you can see the tv on the small screen it seems like the video and audio were erased.
    Genius:
  • 1,153 Answers
CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB. 2. VERTICAL BEAM BLANKING ACTIVE, CHECK PIN 4 OF IC401 FOR 3 VDC IF MISSING CHECK IC202 (5V REG) PART # 266P932010, ON THE SIGNAL PCB. 3. CHECK PIN 6 OF IC200 FOR 9 VDC IF LOW OR MISSING CHECK IC203 PART # 270P210010 ON THE SIGNAL PCB. 4. MAY BE INTERMITTENT. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. Now these are the technical terms, if you do not have the experience you may need a qualified person to do this. Hope this helps
Posted on Sep 14, 2007
I hooked up cable to the back of tv but it doesn't
Set may have more than one input, you may be hooked up to the cable fitting when set is on a video input (blue screen means no signal)
Apr 04, 2012 | Mitsubishi Televison & Video
I CONNECTED MY CAMERA TO MY TV TO WATCH A SLIDE SHOW LAST NIGHT. THIS MORNING ALL I GET IS A BLE SCREEN. HOW DO I GET BACK TO TV?
Probably have the wrong "Source" selected... it's most likely still looking for the input from the camera which I assume you are no longer looking at. Blue screen is the "screen saver" mode when there is no signal.
May 30, 2011 | Mitsubishi Televison & Video
Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sunburst pattern on blue screen
Lamp is bad. Where did you buy it? Did you use the Mitsubishi part?
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
