All cables connected - power supply in all other respects OK - events leading to problem : turned printer on and off - now "on" button does not fire it up....
If it does not light up at all , then that means that there is an internal fault or no power is getting to the printer.
Check power cord connection, try unplugging and plugging back. Do this with printer not connected to computer.
If still no luck that there is a broken contact (typically a broken solder joint on printer power socket), or some component had blown inside the printer.
The printer must be taken apart and tested to fix the problem.
EpsonCut the paper manually, then remove the cut paper from the printer. When RELOAD PAPER is displayed, load paper. Cut paper did not fall off. Remove the cut ...
EpsonIf your product does not turn off, try this solution: ... To prevent the print head from drying out, turn the printer back on, then turn it off by pressing the power button.
? 7:13
https://www.youtube.com/watch?v=et0tLRbK4yU
Mar 21, 2013 - Uploaded by HP Printer Support
Learn how to fix your HP printer when it won't turn on or respond when ... the adapter light goes off and the printer wont start!!! what should i do?
DP ReviewNov 3, 2012 - "It is important to always turn your printer off by the power switch (not... If the printer is left on, as soon as it goes to the idle mode the print ... No. The print head capping pads do not fully engage until the printer is switched off.
Oct 13, 2012 - I have an Epson R300, about 3 years old. It's been great but yesterday Iwent to print a page (printer was already turned on) and it wouldn't do ... Just had the same problem with my R300, it locked up and it would not turn off.
First replace the fuse in the plug or try another power lead, if you still have no lights on the printer at all then the printer PSB has failed & will be uneconomical to repair.
The documentation for the epson printer is rather detailed though, and it is possible I missed it somewhere, but I would try the above link for more leads that may lead to a solution.
Maybe try to call Epson technical support for more information: Contact Support E-mail
If you are unable to find an answer on our web site, you can e-mail your question to Epson Technical Support.
Epson Service Center
For products in warranty, please contact Technical Support. If your product is out of warranty, find a service center.
Technical SupportUnited StatesPhone Number: (562)276-7282 begin_of_the_skype_highlighting (562)276-7282end_of_the_skype_highlighting Hours:
Mon.- Fri.
6AM-8PM (PT)
Sat.
7AM-4PM (PT)
CanadaPhone Number: (905)709-2567 begin_of_the_skype_highlighting (905)709-2567end_of_the_skype_highlightingHours:
Mon.- Fri. 6AM-8PM (PT)
You only need the 2 cables you've mentioned Try Disconnecting the printer from the PC and re installing the drivers Don't reconnect the printer until told to during driver install make sure it is turned on.
Power on...press advance button....press down arrowed button until options in printer screen stops...press maintenance button....ink cart replacement appears in window ...press OK
step1..............switch on
step2............press+hold stop,ink,power buttons untill printer switches self of
step3............switch back on and problems should have gone
