Question about Intel Motherboard
Jbl eon musicmix10
Hi , i recently bought a 10 channel jbl mixer and was trying to get an instruction manual for it, can you help please.im not sure how to hook it up through my amp with one set of speakers and then with another set of jbl powered speakers.
    Problem Solver:
  • 6 Answers
This should be your manual, if not, they have a catalogue of a fair few more!
http://audio.manualsonline.com/manuals/mfg/roland/td10.html
Posted on Feb 19, 2008
SOURCE:
Loud buzz/hum started on jbl eon 1500 powered speaker one side only after power cut off and sudden power back on makes same noise on it`s own as well as with mixer etc could this be a transformer...
For some reason the soft on protection circuit has failed. it is not a simple fix and would require the amplifier module to be removed from the speaker to assess the damage.
Mar 10, 2012 | Jbl Eon 515 Eon515 15 Powered Portable...
How to connect SONY DYNAMIC MICROPHONE F-V40 to JBL EON 515 15IN PWRD SPKR yahoo
Several ways. Easiest way is to just hook up mic to speaker via XLR and make sure on jbl speaker switch is set to Mic not Line. ( for volume ). Ideally you would hook mic to a console ( mixer ) and come out of mixers main out (l/r) to 2 separate jbl speakers ( being powered no amp is necessary ) for stereo!
Aug 26, 2011 | Audio Players & Recorders
Hello I recently bought a jbl eon 315 to amplify my roland td9kx2 drums. when i connected it, the volume was really low. Far to low to practice with a band, let alone gig with. I only connected one mono...
I know this is late, but... I ran into the same issue. Apparently on some models, there is round hole further to the left than the square on the diagram in the manual. You have to stick a paper clip or similar object in and depress it. It would be nice if they would tell you that in the manual. I had to call JBL.
Jun 19, 2011 | JBL EON315 EON 315 15 Powered PA Speaker...
Been looking everywhere for this... i just hooked up my PMP6000 to my brand new JBL EON's 305 (non-active), stereo (one cable for A and B) using Speaking to 1/4" cable. My output level was also VERY...
The JBL EON 305's are 8 ohm speakers. The PMP5000 wi;; produce 400 Watts per side into a 4 ohm load (600 Watts peak). Into your 8 ohm speakers, the peak current will be halved while the voltage remains the same so you ACTUAL power per side is 200 Watts. It is hard to know how much you expect to get out of the amp. This power would fill a venue of at least 2000 sq ft. If you need more sound, try borrowing another 8 ohm speaker for each side and parallel them with the EON's as a test. That will double the power and add 3 Db more of sound. Your main slider should be around unity typically. This amp is a class D switching type (very efficient) and runs on +/- 70 volt rails. giving about 45 volts RMS output. At 4 ohms, this is just over 10 amps giving 450 Watts... at 8 ohms this is around 5 amps or 225 Watts.
Please read my tip on Fixya about the ground hazard of channel A when using 1/4 inch cables out of the PMP units... essentially the BARREL of the connector from channel "A" is the HOT,... NOT the tip of the PLUG. Ground the barrel IN ANY WAY AND YOU FRY CHANNEL "A" AMP !!!
Jan 16, 2011 | Behringer Europower Pmp5000 Powered Mixer...
JBL EON G2 15 loud noise.
The noise may be the reason why the speakers were available used. The tweeter may be defective.
Jul 22, 2017 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 problem!
Could be any number of things, the amp may be damaged (do you use these things at high volume?) but if you are only getting bass it could be a fault on the crossover circuitry. Could be a loose wire inside but the build quality on JBL is pretty good so I doubt that.
How long ago did you buy them? If it was recent you may be able to take them back to the shop, otherwise I'd seek a professional repairman.
Btw, did you check the fuse?
Dec 02, 2007 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Intel Motherboard Logo
218 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
