Erythema marginatum
Erythema marginatum is a type of erythema involving pink rings on the torso and inner surfaces of the limbs which come and go for as long as several months. It is found primarily on extensor surfaces. Go to Bing homepage .look at this page.
There are links that show you how to repair this issue yourself (but
they are not very clear and every thing is very fragile inside the XBOX
360) or you can contact me via email at [email protected] and we
can discuss the issue further as I recently repaired my XBOX 360 with
the same issues and it works better than when was brand new. There are additional measures that must be taken besides the x-clamp replacement which are certain heat syncs that prevent it fron sensing false over heating issues.
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on. This solution will fix your problem for sure.Thank you!
i'm going thru this same problem right now...remove the harddrive then reboot the console...if it boots up properly then your hard drive is shot...that was what was wrong with mine..i bought a new hard drive and it work great again
Well the why part of your question can be answered here - http://www.xbox.com/en-US/search.aspx?keyword=one+red+light
They go into many of the error codes, as to how to fix it without voiding the warranty; If it's under warranty send it in to be fixed, or if you're dying to play right now try the 'towel method' shown here - http://www.xbox360rally.com/the-red-ring-of-deathcure-found/
Beware- purposefully overheating your xbox 360 may damage your system further.
Hi, this is a General Hardware Error: Ethernet port. this error is caused by
a problem with the Ethernet port. you will have to send this unit to a local xbox repair shop or, you can send back to the manufacture for this repair.
Unfortunately, due to the integratedcircuitry, this is not a do it yourself. a qualified microsoft tech is needed for this board transplant.
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
my 1 is 2 red lights
