Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire model FDBB2040FSO
WHEN I GO TO START THE WASHER ALL IT DOES IS THE LIGHTS FLASH AND WONT START
  • rtharp35 Nov 03, 2007
    I have the same dishwasher and it is doing the same thing. I have closed the door all the way. It latches and clicks when it is latched. It can't be closed any more. What could be causing this a limit switch that is not making contact?
  • Anonymous May 05, 2008
    I have the same flashing issue. We sometimes get it to work by opening the door and giving it a good swift latch of the door.
    Is there a switch that isn't being closed somewhere?
  • 44 Answers
Make sure the door is shutting all the way. Mine does the same thing if the door is not latched.
Posted on Sep 14, 2007
SOURCE:
Lights flash on my Frigidaire dish washer model #FFBD2407LW0A when trying run it through a cycle. will not start. When I turn power off and back on the heat lights flah.
Good Morning friend, thanks for your post!
Based off the information you have provided your Frigidaire dishwasher is not starting properly. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience this issue it could mean that your control panel or keypad need to be replaced and I would recommend reaching out to a professional technician for proper diagnosis. Hope this helps. -Matt
Oct 06, 2014 | Frigidaire Dishwashers
Frigidaire Front Load Washer wont start!
sounds like you have a very unhappy control panel..unplug it, wait 5 min..and then plug it back in..if it does not reset, then you may want a repair job, no?
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Lights flash on my Frigidaire dish washer model #FFBD2407LW0A when trying run it through a cycle. will not start. When I turn power off and back on the heat lights flash.
Thank you for your post, friend!
From what you are describing it sounds like a possible issue with your keypad or control panel. I would recommend performing a power reset on your appliance which you can do by unplugging the power cord or flipping the household circuit breaker off for roughly ten minutes.
If that does not help correct the issue I would suggest seeking assistance from a professional to come out and properly diagnosis your appliance to avoid any unnecessary part purchases. -Matt
Frigidaire Washer acting strange
when lights flash the unit is indicated an error message, count the blinks and which lights are flashing, then seek out online what error could be. also, very common issue is clogged drain hose filter inside machine, service company should be contacted to properly take apart unit and repair.
Apr 03, 2013 | Frigidaire Washing Machines
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer wont start
unplug from the wall and count to 10 and then plug is back in. If that doesn't work, you need a service call.
Jul 05, 2017 | Frigidaire ATF6000ES Front Load Washer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
219 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
