Makita 10" Compound Miter Saw LS1040 Logo
A
Anonymous Posted on Aug 24, 2013
Milwaukee saw brake - Makita 10" Compound Miter Saw LS1040
1helpful
My 12" Milwaukee Miter saw is making a noise when braking?
Screeching is always caused by dry metal on metal. It need oil on anything that spins or slides. See if the brake actually has fibre pads like the disc brakes on your vehicle.
Google
make model parts diagram
All questions here need full make and model number, plus '(what it is)'. You got 2 of 3 :>D
MILWAUKEE CIRCLE SAW MODEL 6470-21 serl#849ad13360234
either installed wrong --or wiring short ----if you did repair re open saw and check wiring ,connections and install of component if done by shop return for them to fix
1helpful
I have a Milwaukee circular saw, 6365, and am replacing the switch. Need a wiring diagram!
Scott,
What is the serial number on your saw? I need that to make sure I get the correct info for you.
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
Brand new saw. Vibration so heavy it's nearly impossible to use. Had two previous identical saws. Both ran smoothly with minimal vibration. Would still have those saws if not stolen. Used this saw twice....
immediately return it to place of purchase, it is defective and it is still under warranty! it is very rarely that there is something wrong with them, even broken blade is easy removed, but you described just something wrong from manufacturer side.
i have several milwaukee tools, including sawzall, love them, but they 28volt batteries sux...
I need a wiring diagram for Milwaukee 6230 band saw
go to "milwaukeetool.com" and with your model and serial (just the first few number) you can download a wiring schematic that is in complete detail for this tool. Let me know if you need more assistance.
Milwaukee reciprocating saw blade piston turns, allowing blade to flip flop around. Can this be fixed?
yes it can, probably the spindle or the primary wobble plce I would also check the conition of the front bushings and also the rear. You can go to Milawukeetool.com for a parts exposion on this tool.
1helpful
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
2helpful
I just bought a used Milwaukee 6230 metal portable band saw and would like to get the manual and parts list for it any suggestions?
Hi, This is a link for the parts diagram. Sorry I can't help with the manual. Scroll down to just about half way for your model.
Hope this helps.
toolpartsdirect.com/milwaukee/milwaukee-52.html
Top Makita Saws Experts
Sean Wright
Sean Wright
john h
Are you a Makita Saw Expert? Answer questions, earn points and help others
