FixYa.com
Tags:
Networking Hubs and Switches
Generic problem for all Networking Hubs and Switches
Setting up 16 port switch (by 7 users)
posted by lalit_singh on Sep 08, 2007
i want to set up a home client server network using the 16 port d-link switch.its model no. is DES-1016D.sir i dont know how to establish the network please provide the full step by step description and the guidelines with the manul.kindly do the needful.thanx in anticipation.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by jjloots123, posted on Aug 06, 2008
how do i set up a switch
Comment by hawre, posted on May 20, 2008
hello
i have 3com 8port switch model:3cfsu08. install the switch in network with cable with 5 pc.but the NIC has no byte recieved. but can send.pc cannot ping each other.
Comment by danielhurt, posted on Dec 13, 2007
Hello, I have 5 computers in my small office. I have a 24 port ethernet switch with 5 cables going to each computer. I next connected all the computers to the switch and ran network wizard. When i try to get online with with any of the computers it says limited connectivity. What all can I do to fix the problem?
Thanks,
Daniel
Comment by Guest, posted on Dec 13, 2007
i want to set up a small office network
Comment by dwaynecheng, posted on Dec 10, 2007
sir,
i have already connected one of my pc to an internet with d-link network hub 24-port switch.the ones being connected is said to be a server.using a router, i am able to connect to the internet with the router connected directly to my computer and another network cable connected from my computer to the hub using a LAN card.now the problem is that when i try to make another connection that is, i connected another network cable from the hub to the SiS port of the other computer, notification reads:"connected" but reality stays....it was not connected.what would i do?i already played with IP adds but still it doesn't work..
Best Solution
posted on Sep 09, 2007
Helpful (85)
Deepak_1117
Rank:Apprentice Apprentice
Rating: 89%, 8 votes
Dear
This is the step
You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved:
Take stock of your existing hardware.
If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host.
Decide what type of network technology you wish to use.
Make a list of the hardware you need for each computer.
Install the network adaptors and install your modem on the ICS host computer.
Physically cable the computers together.
Switch on all computers, printers and other peripherals.
Make sure the ICS host is connected to the Internet.
Run the Network Setup Wizard on the ICS host.
Run the Network Setup Wizard on the other computers on the network.
Let's take that step by step.
1. Take stock of your hardware
Note each computer's location and its hardware, including peripherals such as printers and modems.
2. Choose your ICS host
If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host.
The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps.
Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall.
3. Choose a network technology
The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers.
If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead.
Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch).
If you have a high-speed Internet connection, a high-speed router is a good option.
The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home.
If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range.
4. Make a list of hardware needed
Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP.
5. Install the adaptors
Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each).
6. Cable the computers
Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route.
If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors.
7. Switch it on
8. Connect the ICS host
Go to the ICS host computer and make sure it is connected to the Internet.
9. Run the Network Setup Wizard on the ICS host
To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue.
XP's Network Setup Wizard takes much of the pain out of setting up a home network.
The Network Setup Wizard will guide you through:
Configuring your network adaptors (NICs).
Configuring your computers to share a single Internet connection.
Naming each computer. (Each computer requires a name to identify it on the network.)
Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network.
Sharing printers.
Installing the Internet Connection Firewall to guard you from online attacks.
10. Run the Network Setup Wizard on all computers
To do so:
Insert the Windows XP CD in the first computer's drive.
When the XP Welcome Menu appears, click Perform Additional Tasks.
Click Setup Home Or Small Office Networking and follow the prompts.
Repeat steps 1 to 3 for each computer on your network.
Make sure you maintain an active Internet connection on your host computer as you proceed through this process.
geekgirl.tip
If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk:
While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk.
Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive.
Double-click My Computer.
Double-click 3½ Floppy (A:).
Double-click netsetup.exe.
The quickie XP network
If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration.
That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME.
Using your network
Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places).
The Task Pane in My Network Places lets you access computers on your network and adjust settings.
The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers.
Sharing a printer
With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.)
To share a printer, on the computer which is directly connected to the printer:
Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.)
Click the printer you wish to share.
Click Share This Printer in the Task Pane.
In the printer's Properties dialog, click the Sharing tab.
Click Share Name and OK.
Make a printer accessible to others on the network by sharing it.
Once a printer has been shared you can access it from other computers on the network. To do so:
Click Start -> Control Panel -> Printers And Other Hardware.
Click Add A Printer.
In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter.
In the next screen, select the option to Browse For A Printer and click Next.
Select the appropriate printer from the list and continue with the wizard.
Sharing files and folders
Sharing a folder is even easier than sharing a printer:
Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder.
With the new folder highlighted, click Share This Folder.
In the Sharing tab of the Properties dialog box, select Share This Folder On The Network.
Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1.
You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files.
There are a variety of ways to access a shared folder. Here's one way:
Click Start -> My Network Places -> View Workgroup Computers.
Click the computer whose files you wish to access and then click the shared folder.
You can create shortcuts to shared folders to make them easier to
gdfgf
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 07, 2008
Not Rated (0)
Fuxi
Rating: 0%, 0 votes
Nice, but i still have a question.
I had 4 Computers running with a Netgear rp614 Router on my broadband internet. Then i got 3 more PC's, but the new PC's must have the same internet connection. So i bought the Netgear fs608 8-Port switch, and connected the switch to the Netgear rp614 router. Then i connected some of the PC's to the switch, and ... the DHCP didn't work.
Then i tried to acces the internet through the switch and the router with static IP's, but that didn't work, the Computers could ping each other, but not the router...
So why can't they ping the router?
Information: There is no hardware problem with the cables, the IP adresses have been in the class C network (192.168.0.0). The router did not recognize the other hosts too (Routerstate - Connected PC's)
thanks in advance
This Problem Also Relates To: HP ProCurve 24x10/100 Mbps Networking Hub HP ProCurve 408 Networking Switch 3Com (3C16593BN) 24-Port Ethernet Hub 3Com LinkBuilder TP/12 Networking Hub 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch 3Com SuperStack II 610 Networking Switch 3Com (0662705440309) 16-Port Ethernet Hub
Can you Help with these Networking Hubs and Switches problems?
Trendware TRENDnet TE100 S32plus (TE100-S32+)...
only works on 1
hey i have two internet... Answer This...
Encore ENU-4USB 4-Port External Mini USB Hub
ESHUSB-4P hub problem
Was using this hub with Compaq... Answer This...
N-tron 9000 problem.
I have an N-tron 9000 that has... Answer This...
Trendware 8PORT SMART POE SWITCH SNMP VLAN...
can we able to trunk one vlan...
sir can we able to trunk one... Answer This...
Power Dsine (pd-6006/ac/m) 6x10/100 Mbps...
PD-PH-4006/AC/48-INTR
6 INTERMEC AP 2101B connect to... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by edgar1015, posted on Dec 05, 2007
is it only the host pc needs to connect to broadband and the other pc to host?
and the member pc needs only NIC?
Repair Service
Find Networking Hub and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
