Question about SanDisk Sansa c200 MP3 Player
Computer not recognizing player
I've read all the instructions - won't work. Also has a lock on that i can't remove ? HELP !
  • 1 more comment
  • michally86 Nov 09, 2007
    Computer (XP sp2) does not recognize the Sansa c200 and can't copy files to it
  • Anonymous Dec 04, 2007
    computor doesn't recognize mp3 player
  • hhhhhhhh Dec 24, 2007
    Computer not recognizing player and also player is not starting.when you switch it on it just shows sandisk on screen and then turn off
There is a lock button on the side, slide this across.
Posted on Nov 30, 2007
Well buddy heres the problom on the side with the rec. on it ther is another slide button that says hold if u hold the mp3 in the right position slide it to the left
Posted on Oct 11, 2007
SOURCE:
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Encryption accessibility
I met the same trouble, i just reset acer password by the following steps,
Step1.Download Smartkey Windows Password Recovery from recoverlostpassword.com anddecompress it on that PC. There is a .ISO file. Burn the .ISO file to CD or USBFlash Driver.Step2.Get out the newly created CDor USB Flash Driver and insert it to the locked computer.Step3. Re-boot the locked computerand then follow the process of instructions. Just after a few steps, the oldpassword will be removed.It can recover all Windows version.
May 14, 2012 | Acer Aspire One A150-1049 Notebook
My cpu won't recognize my LACIE Minimus Drive. I have no Setup Assistant and I need the info locked on the drive. What do I do?
Go download EASEUS Partition Master 5.8.1 Home Edition (free). I've found it very useful to check and often repair drives that won't mount.
Feb 26, 2012 | LaCie 1TB Minimus USB 3.0 Desktop - 301961...
Hi my computer is not reading that camera is connected..can you please help as i need to load photos on..Thank you Dette Schembri
Is this the first time you've connected it?
Did a data CD come with the camera? Still got it?
If so, insert it into the computer and follow the on-screen instructions that should soon appear.
This is loading an 'operating driver' for the camera to be 'recognized' by the computer in all future use.
Alternatively, remove the camera memory card and put it in a card reader, a device available very cheaply from five & dime stores upwards (or Poundland if you're in the UK)
This will be recognized instantly by an USB 2.0 and upwards connector on a computer.
Sep 24, 2011 | Fuji Finepix S5800 Digital Camera
My computer won't read the new camera I've got. Even after installing all info from cd. Have tried camera and it works on tv. It won't let recognise the device on problem either. What can I do?
A camera that works connected to a TV without software is not the proper device to connect to a computer. Check again with your packaging and instructions.
Having a camera working on the computer and then porting the video signal to a TV monitor is the preferred arrangement.
Install the software, reboot, then connect a PC camera, it should be recognized and be testable on Skype, etc.
Sep 12, 2011 | Dell Dimension 3100 PC Desktop
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
My computer can`t read the MP3 player...What Should I do? I want to mention that I`ve lost my CD:D
Do a google search and see if you can find a free download of your manual. Had you connected your player before? Could your computer read your player before?
My computer doesn't recognize my MP3 But, I can connect it like it is an external drive with no problem.
Oct 29, 2009 | SanDisk Sansa m200 (2 GB) MP3 Player
Computer not recongize the rca th1602 mp3 player
The first time I tried to restore the firmware in my Pearl it would not recognize it. I had to follow all the troubleshooting instructions that popup when you run the software. Basically, try taking the battery out and waiting 10 seconds or so. Run the software and read all the instructions at the bottom of the popup window. then hold the play button, plug your player in, and keep holding that button until the software recognizes it. It works.
May 05, 2009 | RCA TH1602 MP3 Player
Computer won´t recognize my player
format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
reboot your computer. put the battery back in the player.
plug it into the usb port on the computer. worked for me
Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
