Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson EWC27T3 On top of the picture I have about two (2) inches black and below I have about six (6) of ghost lines across. I know it is a vertical problem. I don't have the schematics. Can someone tell me how to fix this problem? Thank you
    Genius:
  • 1,139 Answers
Your vertical coupling capacitor is going bad, without a schematic you don't know which cap this is. Might I suggest that you get a schematic from the vendor or from one of the site on the web that carry schematics. To fix this problem you need to know which cap is the vertical coupling capacitor.
Posted on Sep 19, 2007
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
100 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
