Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
My c340 freezes. i have to turn back on the power to get it going again. i spoke with support, who had me reset the device. it still freezes. i also notice that the battery drains quickly. it was fully charged, i just went on a 2 hour drive and it is out of power...and i had it plugged into my cig lighter. i am trying to rechage it with the usb cable now. no bars are showing as charged. if you have any ideas, please let me know, thanks, mark
  • 1 more comment
  • themuse1 Oct 04, 2007
    I ended up having to send the gps to garmin for repair. They told me there is a known problem with the battery. They sent back a reconditioned unit, and it is working fine!
    Mark
  • Anonymous Nov 08, 2007
    The GPS freez in one location. I try to reset it, sometimes it work and sometimes it does not work
  • alosha12 Jan 20, 2009
    i need it upgraded fof free if i can because its battery drains quickly
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Posted on Jul 17, 2008
My garmin c340 while driving shut down will not power on back then a bussing noise all night try to power on will not come on the foll eve try iy came on 2 secs and died anyhelp on this
Posted on Jan 14, 2009
My c340 battery won't take any charge, and I recently started having lockups when I tried to use it. I updated the systems software to v4.40 and that seems to have done the trick.
Posted on Oct 01, 2007
SOURCE:
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Jun 03, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 350-can not change the location it is stuck on
you may need to reset it, as in resetting the c340, turn off and then press back on again, if this does not work maybe the reset button is in the same place as it is on my c340, instructions for the c340 is as follows: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plat, press the reset button, turn the unit back on and hopefully it will operate normally
Dec 28, 2008 | Garmin Nuvi 350 Car GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Jul 04, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
876 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
