Question about Harman Kardon CDR30 2-Disc CD Recorder
How to finalize a cd from an harman/kardon cdr30. Thanks Mathieu
  • 112 Answers
Press finalize then press the play button within 5 seconds.
Posted on Jan 22, 2008
My hk cdr 30 no reading any digital audio inserted disc. otherwise everything
CD do not just read any types of files, the disc must contain only files compatible with the unit. Check your manual.
Jan 20, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Says NO AUDIO and I have replaced the disk with several other CD-R
it sounds as if the disc was recorded as a data disc cd instead of a audio cd play the disc on a computer to check it
Dec 20, 2012 | Harman Kardon CDR30 2-Disc CD Recorder
Can't' play blue ray disk
It is a CD Player, It will not play DVD,s
Oct 21, 2012 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I have a harmon kardon cdr 30 cd recorder. After a power outage the unit no longer turns on. A surge must have blown something.
Hi
First thing to do is disconnect the unit from the mains supply for 15 mins to allow for a hardware reset,and then power it up and try again. If it does not come up, then the power supply has been damaged by a power surge associated with the outage. You may have no choice but to take the unit to an authorised HK repairer. Let me know how you get on with resetting the unit. Please take the time to rate this solution. Happy to talk to you more about it. Cheers
regards robotek
Jul 15, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
I can't open the tray on the recorder side.
I had similar problem with both drawers. The belt from the drive motor to the drawer pulley is worn. mcmelectronics.com has two belts 42-1050, 42-045 that are close enough in size to work. Remove cover, press down on tray, slide tray forward about half way and you will see the worn belt. Total cost of fix is about $12.
Dec 16, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
94 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
