SOURCE: Samsung ML 2510 feed problem
I purchased the printer new in a box from ebay. Samsung agreed to repair the printer under guarantee. The repair shop has fixed the printer easily apparently. There was a gear out of line which once readjusted ensured the printer works properly. I have not taken the printer apart myself but this should be straight forward. No need attempt if the printer is still under guarantee.
SOURCE: samsung ml-1710 printer continues to jam paper;
pickup roller and seperaion pad req changing
SOURCE: Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
SOURCE: Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
