Question about IBM Netfinity 3500 M20 8657 Server
Two cpu's hello again, i have two tualatins 1200 processors..(with a lin-lin convertor)=>look at ebay i want them both in my machine for a 2400 mhz pc.. he accepts only one.. i switched them, the convertors too.everything works, separatly though but.... with two he doesn't even starts up. the processors are the same type:sl68p 1200,100,256,1.5 volts.. do i need that voltage regulator (srv)? btw why is the dummie on socket #2? without that he works fine my big question is: what am i doing wrong? thanx thanx thanx
  • 661 Answers
The dummy voltage reg is just to complete the power loop, (as there is built in diags in the box) without the dummy the box will log errors against the empty volt reg slot. YES you do need the Voltage regulator for the 2nd slot if you intend to install a processor there.
Posted on Sep 11, 2007
SOURCE:
Hello, I have the emachines EL 1200 - 06w PC desktop. I would like to connect an HP 4000 N printer. The printer has parallel connector. This computer does not. Is there a way to connect the printer?
On ebay search for USB to Parallel convertor. It is available, very inexpensive and useful. I have one for my older printer. You will need drivers from hp.com when it is connected to get it to work properly.
Feb 10, 2011 | E-Machines eMachines Desktop PC
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Soyo SY-7VMA-B -supports P-3 tualatin (.13u) CPU's?
when looking for a cpu for the socket 370, be sure to NOT get the socket 370 cpu that is made for servers.
this type requires a motherboard made specifically for that type cpu.
use a search engine to find out how to tell if it is a socket 370 server CPU, there is not enough space here for me to explain it.
in that search you will also find out how to determine the answer to your question about cpu's supported by that motherboard..
most socket 370 based systems run pretty well, so you have a good machine there, and it's worth your time to keep it running, and to upgrade it.
Nov 07, 2009 | Computers & Internet
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Asus P3V4X/S370-133/Tualatin 1.2Ghz
It turns out that while the BIOS will not appear to recognize the Pentium 3 1.4GHz Tualatin CPU (SL6BY) in my Asus P3V4X motherboard, Windows XP does! I apologize for my delay in posting this.
I have five extra SL6BY processors that I'd like to sell if anyone is interested. I need to make some money to upgrade the memory in this antique to 2GB (turns out that low density 512MB RAM does work in the P3V4X, by the way).
Thanks,
Eric
Nov 22, 2007 | ASUS (S370L) Processor Board
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
IBM Netfinity 3500 M20 8657 Server Logo
98 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
