Hi Manny First thing is Drain all the oil back out. You have most certainly overfilled it. Try and get as much out as you can from the same place you filled it from. Leave it tilted back until it stops running and then put the mower level for half an hour. Check the oil level now and clean the spark plug and replace it. There will still be oil in the air filter due to over filling. Only put oil in one egg cup at a time until its below max on the dip stick. Run the mower for 20 minutes and burn the smoke off. It may smoke for a few times but thats ok.
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
SOURCE: craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
SOURCE: I have a Craftsman 650 series lawn mower. It
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
