Question about Navman iCN 520 GPS Receiver
Navman icn 520
I cant get it to go passed the start up screen of the car and cant delete things on it to reinstall software
  • Anonymous Nov 09, 2007
    MY NAVMAN ICN 520 WILL NOT GO PAST THE FRONT SCREEN
    New Friend:
I recommend going on amazon.com and it is $130
Posted on Dec 16, 2013
There should be a battery On/Off switch on the back. Have you tried turning it off, leaving it for 10 seconds then turning it back on?
Also, there should be a reset button either on the top or on the back. Hope this helps and solves your problem.
Regards
Matt
Posted on Nov 05, 2007
SOURCE:
Lost my icn 520 map cd
Contact (I believe its Garmin for that model). I think you will have to buy another copy of their software. If your maps are more than a year old, they are due for an update anyways.
Jerry G.
Jun 27, 2008 | Navman iCN 520 GPS Receiver
Not starting
This sounds like you have an issue with the software install on the device.
Have you tried to unlock the device before, and this has gone wrong?
Does the device connect to a PC via active sync? if so can you browse to the \my flash disk folder?
If you can use active sync then there is a good chance that you can salvage your device. :)
Jun 22, 2008 | Navman iCN 520 GPS Receiver
Update maps for iCN 520
You can not update the official Navman maps on this device. You can however unlock the iCN520 and install other GPS software on it. The iCN520 can run virtually all the major GPS software available today; from Tomtom to Miomap and beyond.
Instructions on how to unlock the iCN520 can be found at:
Once unlocked you can even install games, emulators and several PPC applications. With Coreplayer installed you can watch movies and listen to mps3 from the Navman.
Example of an iCN520 running MacOS 7.5.5
May 23, 2008 | Navman iCN 520 GPS Receiver
Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
May 11, 2008 | Navman iCN 520 GPS Receiver
Navman icn 520
There are two possibilities:
1) it is a software problem, in this case you can solve it downloading and installing a firmware update. You can download latest software from here.
This is most likely situation.
2) If the above did not work it means that you have an hardware problem, probably the touchscreen is slightly faulty, or the lcd ribbon cable is not well connected. In this case I suggest to take the navman to service.
Regards
Mar 29, 2008 | Navman iCN 520 GPS Receiver
Navman icn 520 with smartST 2005
You can unlock the iCN520 and install other GPS software on it. The iCN520 can run virtually all the major GPS software available today; from Tomtom to Miomap and beyond.
Mar 22, 2008 | Navman iCN 520 GPS Receiver
Navman iCN 520
The CD is not available for download from Navman it seems, but you can get it at thepiratebay.com. Just search for 'navman icn' and you'll find what you need, I just did. Better learn how to download torrents though! :)
Feb 14, 2008 | Navman iCN 520 GPS Receiver
No volume control
is there any indication that the volume control still works?
Jan 17, 2008 | Navman iCN 520 GPS Receiver
Navman iCN 520 GPS Receiver Logo
143 people viewed this question
Top Navman GPS Experts
Ekse
Marvin
Marvin
Are you a Navman GPS Expert? Answer questions, earn points and help others
